Framing Shower - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-03-2019, 12:35 PM   #1
Rewards Points: 26
framing shower
I am installing a shower in my basement. My width is 40 and 3/4. The standard shower is 36x36 unless you go with a corner shower which I cannot do. My question is how would you go about framing in the difference with the 4 inches left. It is a permanent wall so I have to figure out what to do with this 4 inches I have left. Hopefully I can get some good ideas on what to do. Thanks everyone.
mammaw810 is offline   Reply With Quote
Old 02-03-2019, 12:50 PM   #2
retired framer
Rewards Points: 18,792
Re: framing shower
Just build a wall at 36"
Old 02-03-2019, 01:31 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,676
Re: framing shower
Unless the wall can be moved a couple of inches the other way to give you an opening of 42 x 36. I like bigger.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 02-03-2019, 02:54 PM   #4
Rewards Points: 26
Re: framing shower
The walls cannot be moved. I wish they could because I would love to have it bigger. I just wasn't sure if building something 2 inches on each side would work. I have to tie the shower into the wall there and this is why I will have 2 inches on each side left after I install the 36 inch shower. My only opening is 40 inches
Old 02-03-2019, 03:34 PM   #5
Naildriver
chandler48's Avatar
Re: framing shower
I know you say they can't be moved, but I do it for a living and if it were put together, it can be removed. Is there a reason it can't be moved, or altered to give you the added 2+"? I am not doubting you, I just want to make sure all the avenues have been looked at.
Larry......
Old 02-03-2019, 03:48 PM   #6
Rewards Points: 26
Re: framing shower
The walls already exist and have already been built before i started this project. I am putting in a saniflo access 3 system and the sink and shower have to be put in to connect to it. The space is only 40 inches wide. I know its going to be a small bathroom but it will serve the purpose when people come to stay. They will have there own private bath. I can only get a 36 inch shower the way the walls are built. I looked for a 40 inch shower but they are all corner showers. I'm happy you are being patient with me. I really appreciate it. My concern is having the 2 inches on each side left to deal with. Wasn't quite sure what to do with it to make it look right.
Old 02-03-2019, 04:17 PM   #7
Naildriver
chandler48's Avatar
Re: framing shower
Just wanted to explore all options. The best you will be able to do is move the walls closer by building a sub wall and close it in to accommodate the 36 x 36. Good luck and ask away with questions if you need to.
Larry......
Old 02-03-2019, 05:15 PM   #8
Rewards Points: 26
I would like to run the 2x4's on each side perpendicular to the studs. Then frame over it with rigged board. Do you see anything negative to that?
Old 02-03-2019, 07:34 PM   #9
Naildriver
chandler48's Avatar
Re: framing shower
You can run your 2x4's horizontally over the vertical ones if you want, but you need to address the corners which must be vertical for support of your cbu
Larry......
Old 02-03-2019, 09:39 PM   #10
retired framer
Re: framing shower
Cot strips of 1/2" plywood and add to the studs on both sides, add 2x4s on the flat to each stud, and top plate, put a 2x6 cover on the bottom plate,
Old 03-09-2019, 12:17 AM   #11
Rewards Points: 2
Re: framing shower
You have to build a wall of 36".
allensolly is offline   Reply With Quote
Problematic shower oneonesix Plumbing 25 12-28-2014 11:52 AM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
2 by 6 framing for shower stall spring3100 Kitchen & Bath Remodeling 9 01-04-2012 12:50 AM
framing to support shower seat? ratherbefishing Kitchen & Bath Remodeling 2 12-26-2011 12:08 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
