Framing Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2016, 05:09 PM   #1
Rewards Points: 4
Framing Question
I am getting ready to do an addition on our house. I will be removing a load bearing wall. Can I install 2x6x24' across the span of the room if I marry the 2x6's to the existing 2x4 rafters. My current rafters are on 24" centers and I will be making them 16" centers, or do I need to install a header where the existing load bearing wall is?
rbicknel is offline   Reply With Quote
Old 11-30-2016, 06:06 PM   #2
Rewards Points: 17,884
Re: Framing Question
So far we have no pictures, no idea where you are since there's no location mentioned in your profile.
No idea what's above this area.
All this should have have been run though your local zoning dept. permitted and inspected.
Old 11-30-2016, 06:50 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,228
Ayuh,..... That would be correct,....
Old 11-30-2016, 06:51 PM   #4
Rewards Points: 4
I don't have any pictures to post at this time. I don't have a local zoning department as I am outside the city limits. I didn't know that I needed to post my location. I am in Joplin Mo. This is an exterior wall with nothing above, current truss system is on 24" centers.
Shed Roof Fascia and Framing Question crhage Building & Construction 3 06-22-2011 06:54 AM
Above grade framing and a few framing question jreed Building & Construction 6 01-16-2010 10:56 AM
Framing Question flati Building & Construction 10 01-12-2010 10:24 AM
Balloon Framing Question zetti1102 Building & Construction 2 09-30-2009 09:50 PM
stupid framing question amakarevic Building & Construction 12 02-23-2008 03:29 PM
