Framing Issues Discovered During Kitchen Remodel - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-21-2018, 11:13 PM   #1
Rewards Points: 528
Framing issues discovered during kitchen remodel
My house is 90 years old and the problems I discovered after tearing off the lath and plaster donít seem to be affecting the structure - ie: there is no sagging, etc., so I am tempted to let sleeping dogs lie. On the other hand, if there ever was a time to correct these issues, it is now. Looking for input from the experts.
First issue - someone in the past cut a 2Ē notch, up from the bottom of a 2x8 joist, right in the middle of a 12 foot span. Best remedy? (Picture 1)
Second issue (part A) - there is an archway between the kitchen and a small eating area. The span is about 7 feet. The 4x8 beam supporting the span is not bearing correctly on the framing. On one end it bears on a stubby 2x4 that is ultimately supported by double horizontal 2x4 nailed across the stud bay. On the other end it is simply toe nailed to the side of a 2x4 stud. And there is more... (part B) immediately beside the end of the beam, someone haphazardly removed studs to create a recess for a fridge. So there is considerable weight bearing on one 2x4. I think I know what I am going to do but would like to hear from others.
Framing issues discovered during kitchen remodel-df90c306-312e-4dc6-83f7-54c06a68d397.jpeg   Framing issues discovered during kitchen remodel-2a4afcb7-e72c-4aee-8eaf-913b173833c4.jpeg   Framing issues discovered during kitchen remodel-0a434886-d75a-412d-a365-d1846e5fda8f.jpeg
Windows is offline   Reply With Quote
Old 03-22-2018, 12:16 AM   #2
retired framer
Rewards Points: 18,616
Re: Framing issues discovered during kitchen remodel
The one thing working in your favor is very old, old growth lumber that can take much more abuse than todays lumber.
You could screw a 2x4 about 4 ft long to the joist with the notch.
Almost every header we put in a house is double 2x10 now, look at the headers over you windows.
That said I would still do something with the headers. I would remove the arch curves or cut enough to slide a stud in under the beam. The other one I would leave the two top plates and rip that out and put some kind of header with a stud under both ends
Then have a look below the floor because bearing points like that should have support right to the footing. It might stand like that for another hundred years but it would be a shame not to fix it while you have it open and not much more than an hours work.
The Following User Says Thank You to Nealtw For This Useful Post:
Windows (03-22-2018)
Electrical Work for Kitchen Remodel epsilono Electrical 13 05-02-2016 04:20 PM
Barndominium addition and Kitchen remodel mr-fixit Remodeling 5 03-16-2016 12:18 AM
Kitchen remodel monst3r Electrical 0 07-17-2015 12:06 PM
my kitchen reno - complete remodel (with concrete countertop) Knucklez Project Showcase 311 07-07-2014 05:07 PM
Unintended kitchen remodel Itsdanf Project Showcase 191 06-14-2010 11:23 AM
