Framing Help?!?! - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 03-09-2018, 04:59 PM   #16
Rewards Points: 8
Re: Framing help?!?!
I agree that needs moved and should have been a long time ago. I can't believe it passed code for me to buy it. I may eliminate that Run for that ball valve all together.. it's for my house it side may move that..
Nealtw likes this.
Rgbaseball is offline   Reply With Quote
Old 03-09-2018, 05:57 PM   #17
Rewards Points: 8
The other drain hose that goes into the PVC do you feel that is an issue where it is?
Old 03-09-2018, 06:24 PM   #18
Master Electrician
Rewards Points: 5,018
Originally Posted by Nealtw View Post
Let's start over. I am sure it is ok for permanent plumbing to be above the box. If a valve leaks and shorts out things in that box, who gets to turn things off.
Have you a plan for an access panel for those water valves. Can they be moved around so they both or all could be accessed from the same panel away from the panel.
You have a connection between a black hose and the white pipe. could that just be reconfigured to somewhere else.
It is NOT okay for plumbing above a panel.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Nealtw (03-11-2018)
Old 03-09-2018, 06:43 PM   #19
Rewards Points: 1,406
What does it drain ?
Gregsoldtruck79 is offline   Reply With Quote
Old 03-09-2018, 07:05 PM   #20
Rewards Points: 8
Dish washer
Old 03-09-2018, 07:34 PM   #21
Master Electrician
Plumbing code violation. .
Old 03-09-2018, 07:53 PM   #22
Dish washer
Wow, nothing sez fireworks like a dishwasher drain hose coming loose and spraying a main electrical breaker box. Just kiddin RG, (sort of)
Looks like 3 options in my opinion.
1. Put it back like it was and forget about it. The home was purchased as is, and accepted and insured as is. Make changes, then you have flies getting in the ointments.
2.Looks like you either have to budget about probably $1500.00 + (?) for a pro plumber and sparky to fix your wrong stuff or....
3. Get on UTUBE and see if it is something you may want to work on a piece at a time. All while knowing there are shady people making videos on UTUBE also.
Watch a LOT of videos for the same needed work, and then use common sense and this board, to pick out which one would be best to do your project ....from what you learned from it. All JMO though
Replacing drywall and possibly framing SrsBidness28 Remodeling 1 08-18-2013 08:12 AM
Framing of opening in ceiling Out2pasteur Carpentry 1 04-13-2013 03:51 PM
Basic help with window and door rough framing danf26 Building & Construction 3 08-20-2012 10:51 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
