Framing - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 07:45 PM   #1
Rewards Points: 71
Framing
I have done the bottom plates in my basement but now I have cut the wood for top plates and I noticed some tubing that runs about half an inch below the floor joists where I was going to connect my top plates. I'm not really sure what to do. Should I go buy some furring strips? If I use furring strips do I need to lower all the top plates even though it is only two walls or top plates that are obstructed by the tubing?
RichTibo is offline   Reply With Quote
Old 11-23-2013, 08:58 PM   #2
Rewards Points: 17,890
Really need a picture.
In most cases the pipe could be rerouted through the joist, the top plate could be run from two different directions leaving a space where the pipe is.
All depends, could tell better with that picture.
Efficient framing and framing lumber Geran Brown Building & Construction 13 11-17-2013 01:24 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
