Frameless Shower Door Hinges Through Fiberglass - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By RickMacKay
Old 03-22-2017, 04:03 PM   #1
Rewards Points: 22
Frameless shower door hinges through fiberglass
Hello!
I recently remodeled my basement bathroom. My wife now wants a frameless shower door. I purchased hinges, a knob, and seals. I'm waiting to buy the custom glass until I know I will be able to successfully mount the hinges.
My hinges can handle 3/8" and 1/2" glass. 3/8" glass for the opening is going to weigh about 72 pounds. That's about 24 pounds per hinge (they are rated up to 40 pounds each). Each hinge has 4 screw holes. The wall has cinder blocks, 1" insulation, a stud, and then the fiberglass shower (I attached a diagram). It's 3" from the edge of the fiberglass to the stud. The inside screws will need to be angle to hit the stud. The screws will need to have spacer sleeves so that the fiberglass doesn't crush when they're tightened down.
Does anybody have any experience with this? Will screws with that much space before reaching the stud be able to handle the torque? What do I use for spacer sleeves?
Thanks,
D
Dissonance is offline   Reply With Quote
Old 03-22-2017, 05:13 PM   #2
Rewards Points: 17,896
Re: Frameless shower door hinges through fiberglass
Blocking should have been added behind the wall before finishing.
No way would I have bought the hardware then try to find the doors!
Any real glass company could have ordered you the whole thing made to size.
Old 03-22-2017, 08:05 PM   #3
Rewards Points: 22
The only blocking is what I showed in the diagram.
Special ordering the glass is not going to be a problem. There's only one glass guy in my town, and he specializes in auto glass. If I go out of town, I will have to rent a truck. I did not order a unit because I couldn't find them with antique brass hardware. The glass is not the issue.
Old 03-23-2017, 09:39 PM   #4
RickMacKay's Avatar
Rewards Points: 114
You have to screw it STRAIGHT into wood blocking. There is no other way. Have your wife screw it in, she picked out the Euroglass, she can deal with it when it falls apart and breaks. No professional installer would do that.
MonsieurBon likes this.
RickMacKay is offline   Reply With Quote
Old 03-26-2017, 09:04 PM   #5
Rewards Points: 22
Thank you for the professional advice, but did I do something wrong to be treated so rudely?
Old 04-02-2017, 08:06 PM   #6
Professional
Rewards Points: 188
You might need to do another remodel to get blocking in there OR have the Glass Doctor do a custom measure and install for you. It's pricey but worth it. They may have some solutions.
Str8AheadInc is offline   Reply With Quote
Old 04-02-2017, 08:11 PM   #7
Rewards Points: 22
I think your conclusion is correct. I'm still trying to find a local person to come look at it, but that's hard to get done in my small town. Removing the fiberglass insert to put a block behind it is looking like it's going to be necessary. If I do that, I might as well replace the insert with tile. Thanks for your advice!
Old 04-02-2017, 08:22 PM   #8
Professional
Rewards Points: 188
Where's your small town?
Old 04-03-2017, 04:25 PM   #9
Rewards Points: 22
Vermillion, South Dakota
Old 04-03-2017, 10:32 PM   #10
Professional
Rewards Points: 188
There is a Glass Doctor in Sioux City.
Old 04-03-2017, 10:39 PM   #11
Professional
Rewards Points: 188
Here is the last glass job they did for me. I used to use a local glass company but they had bad customer service.
Here it is: http://wp.me/p6B4E8-pfp
Good luck!
Old 04-09-2017, 09:34 AM   #12
Rewards Points: 22
What a great job!
The Following User Says Thank You to Dissonance For This Useful Post:
Str8AheadInc (04-09-2017)
Old 04-09-2017, 12:15 PM   #13
Professional
Rewards Points: 188
Originally Posted by Dissonance View Post
What a great job!
Yeah, they are the deal in my town for custom shower glass. It's pricey but well worth it.
Cut hole in fiberglass shower with recip. saw? Studly Plumbing 12 06-11-2013 09:28 AM
Shower floor: Use ceramic tile or fiberglass base? Eagle One Flooring 1 04-22-2013 09:26 PM
Fiberglass Shower Base with Tiled Walls h2ojetga Kitchen & Bath Remodeling 4 03-22-2013 10:07 AM
Mating tiled wall to fiberglass shower pan? lizardrider Kitchen & Bath Remodeling 6 05-15-2011 01:21 PM
Getting those darn non-slip rubber pads off of bottom of fiberglass shower proofer Plumbing 5 06-15-2008 04:05 PM
