Foam Insulation - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-31-2013, 07:36 PM   #1
Foam Insulation
I'm having an addition built and will be using closed cell foam for insulation
I am wondering what to use between the 2 x 12 floor joists to prevent the foam from going into the crawl space
floor is 2' above grade
someone suggested using bubblewrap or vapor barrier plastic stapled between each joist bay
but not sure best way to mount or thickness of plastic etc
is there any other suggestions ?
the foam contractor says he has never encountered this issue before
Lew
lewisbuttery is offline   Reply With Quote
Old 10-31-2013, 08:06 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
are you using rigid foam or spray foam. if your using rigid foam simply get a few cans of spray foam to use as adhesive for the rigid then spray around the perimeter of the final layer to stop any draft.. no plastic required. type 2 foam is a vapor barrier
woodworkbykirk is offline   Reply With Quote
Old 10-31-2013, 08:16 PM   #3
closed cell spray foam
if they spray between the joists there is nothing to "catch it" and prevent from filling the crawl space
what is best method to keep it between the joists ???
I need 4.5" of foam between joints for R30
Lew
Old 10-31-2013, 10:31 PM   #4
Rewards Points: 17,890
The spray foam I've seen sets as soon as it hits the underside of the subflooring and sides of the joist, very little falls down.
woodworkbykirk (11-02-2013)
Old 10-31-2013, 11:23 PM   #5
I live in the Buffalo NY area
the sub-floor is off and the spray foam is going down into the joist bays
something is needed to keep the foam in the bays
otherwise it will just fill the crawl space below the joists
the crawl space is only 2' tall from grade to top of sub floor
not roomy enough to spray from below
I think one method will be to nail 3/4 x 1 pt strips along the bottom inside edge of each 2 x12 then lay 3/4 pt plywood on those strips to create a bottom for each bay
the foam can then be sprayed on these bottoms
I think that will work better than stapling bubblewrap for bottoms
Lew
Old 11-01-2013, 10:07 AM   #6
GBrackins's Avatar
Rewards Points: 2,108
I take it you want to spray from the top side.
you could use strips of building wrap (typar/tyvek) stapled to the sides of the joists. you'd have to figure out what your require R-values is in inches so you'd know where to place it.
just place the weather side down. good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-01-2013, 10:36 AM   #7
Gary:
thanks, the Tyvek would probably work
the foam vendor called, different guy,
he understood and said that bubblewrap is what they use for
spraying from topside or knee wall etc
where a "catcher" is needed
I'll let me GC decide between Tyvek or bubblewrap
thanks
Lew
Old 11-02-2013, 01:08 PM   #8
Registered User
Rewards Points: 526
Tyvek will work, either side out; it is not "one-way" vapor permeable (58 perms). The logo and stud markings are on the smooth side from manufacturing. The bubble is probably a true vapor barrier. Photo 6; http://www.buildingscience.com/docum...n-crawlspaces/ Notice air "open" to ventilation.
Gary
Old 11-02-2013, 10:29 PM   #9
if their spraying foam they can very easily spray from below and it will not fall out. it sticks to the underside of the sheathing.. they just cant do it all in one pass. we have it done on a regular basis with no issue. and im in a similar climate
Installing XPS foam panels where existing pink bat insulation. Siubeer Insulation 15 06-28-2012 10:27 AM
Spray foam insulation odor Ranger1227 Insulation 6 02-14-2012 11:53 AM
Hybrid Spray/Rigid Foam Insulation yaemish Insulation 4 01-20-2012 11:55 PM
Canned Foam Insulation WindingRoad Building & Construction 5 01-02-2011 09:08 AM
Floor insulation, cellulose vs hard foam Arky217 Flooring 0 12-23-2010 10:44 PM
