Foam Insulate All Basement Walls? - Remodeling - Page 4 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 01-18-2017, 12:37 PM   #46
Re: Foam Insulate All Basement Walls?
Make sure to use faced rigid foam against the mason walls...regardless of water proofing there will still be vapor. If the foam is faced then you can use 2 x 4 insulation and it shouldn't get wet/mold unless you have a plumbing event...combining the insulation will increase the r value as well...
drewjt6 is offline   Reply With Quote
Old 01-19-2017, 07:51 AM   #47
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,330
rigid foam board on basement floor is it good or bad cutnail Insulation 6 08-29-2011 07:48 AM
Did I need to use Foam board in basement? dbeers16 Building & Construction 8 01-04-2011 01:01 PM
Basement subfloor questions FirefighterGW Flooring 56 10-13-2010 02:07 PM
Best way to insulate basement walls / floor? benze Building & Construction 1 09-07-2010 07:17 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
