Flush Door Hinge - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Tymbo
Old 04-05-2019, 06:31 PM   #1
Rewards Points: 138
Flush Door Hinge
I got these cabinet doors hoping i could use them flush on wall (covering a recess/built-in pantry in the wall)
Anyone know what hinges might work with these for that application?
bobmane is offline   Reply With Quote
Old 04-05-2019, 11:42 PM   #2
retired framer
Rewards Points: 18,462
Re: Flush Door Hinge
Maybe a picture of the hole in the wall. The hinges are easy if you have wood to screw to.
https://www.amazon.ca/s?k=euro+hinge...l_2yo9vwdsfi_e
Do not use flat bottom gables with scissor trusses.
Old 04-06-2019, 05:19 AM   #3
Rewards Points: 92
That are termed "European Hinges" and are available through most box stores and probably Amazon.
ChuckTin is offline   Reply With Quote
Old 04-06-2019, 08:13 AM   #4
Rewards Points: 332
Check the hole spacing in millimeters to determine which brand of hinge will fit the pre-drilled holes.
Tymbo is offline   Reply With Quote
Old 04-06-2019, 08:18 AM   #5
Rewards Points: 332
https://lh3.googleusercontent.com/iM...UOu3olHfZW=s43
Nealtw likes this.
Changed A.S. toilet flush valve seal seat disc, still leaking, need advice Rav Plumbing 6 10-05-2018 02:41 PM
1 flush ok or a bit weak, 2 flush very weak, 3 flush always ok Deck Plumbing 9 10-03-2016 12:49 PM
Toilet Poor Flush Flapper Closing too Quick. doolenberg Plumbing 9 06-29-2015 09:07 AM
Flush Valve Seat sticking to Tank Ball Leah Frances Plumbing 2 05-23-2011 06:53 AM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
