Flooring To Replace Knocked Down Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-09-2016, 06:26 PM   #1
Rewards Points: 12
Question
Flooring to replace knocked down wall
I'm knocking down a non-load bearing wall between my living room and kitchen. The new span will be 15' wide by approximately 6". The living room is carpeted with a thick pad and the kitchen has a thin vinyl/linoleum.
I'm uncertain as to what to use in between the the two existing floor coverings. I paced around Lowes for some time today looking at options.
I was thinking a single 5 1/2" laminate floor board with a reducer to the vinyl but I'm not certain how solid this would end up if adhering to the subfloor.
My other thought was to get the proper length of 6" x 1" red oak boards and use my router to step down the end on the vinyl side but I'm afraid 1" will be too thick. I would stain and varnish it to make it look real nice.
I also found a tall baseboard molding that was made out of a hardwood but it wasn't quite wide enough to cover the whole space that the wall + moldings are covering.
Using any type of tile or stone would be out of the question (pet peeve of my wife.)
Any suggestions on what to use to cover the "void"?
MikeMurphyINC is offline   Reply With Quote
Old 01-09-2016, 07:14 PM   #2
Rewards Points: 5,348
You can put in a transitional wood threshold , the cheapest solution. Or you can change one of the rooms and extend the flooring into the gap.
Ron
B. Franklin 1759
Old 01-09-2016, 07:28 PM   #3
Rewards Points: 12
I couldn't find a transitional piece that was 6" wide. I searched all over Lowes. Did I miss it somehow?
Old 01-10-2016, 04:57 PM   #4
Rewards Points: 144
I make custom ones for all of the remodels I do.Do you have access to a thickness planer?
mako1 is offline   Reply With Quote
Old 01-10-2016, 05:40 PM   #5
Rewards Points: 12
Possibly. Two of my neighbors do a lot of woodwork. Do you have pictures of how some of them have come out?
Old 01-11-2016, 07:29 AM   #6
Rewards Points: 144
I can't go t a customers home to take a pic for you but here is a pic of a sample I made for a current job.
These are made with a thickness planer and a simple jig from shop scrap.They can be made any width,with one straight edge or a thickened edge on one side depending on the transition from room to room.
Flooring to replace knocked down wall-untitled-2.jpg   Flooring to replace knocked down wall-dscn0936.jpg
The Following User Says Thank You to mako1 For This Useful Post:
MikeMurphyINC (01-13-2016)
Old 01-11-2016, 02:24 PM   #7
Rewards Points: 12
This is excellent. Thank you.
Old 01-13-2016, 10:20 PM   #8
Rewards Points: 12
Question
Do you have to have a special planer to do that?
Old 01-14-2016, 06:25 AM   #9
Rewards Points: 144
It's just a standard thickness planer with a jig.First you plane the stock to the final thickness. If you want the stock 5" wide you take a piece of 3/4" stock 1/2" wider and long enough to go from the end of the infeed table to the end of the outfeed table.Screw a piece of 1/2" square stock to one edge (top edge) to act as a guide for the stock.Then screw a piece of stock on the opposite edge (bottom)to hold the piece at the angle that you want the bevel.Clamp this to the infeed and outfeed tables and your good to go.
Old 01-17-2016, 01:28 PM   #10
Rewards Points: 12
Does the groove cut out on the under side serve a purpose?
Old 01-17-2016, 01:30 PM   #11
Super Moderator
joed's Avatar
Rewards Points: 23,474
The groove on the underside helps to prevent warping.
The Following User Says Thank You to joed For This Useful Post:
MikeMurphyINC (01-17-2016)
Old 01-24-2016, 09:27 PM   #12
Rewards Points: 12
Thanks for the inspiration! I ended up cutting the slant with a table saw and did the rest with a router table. Oh and a moderate amount of sanding there are three pieces like this. In one I will route vent holes in for the cold air return that was on the wall.
Flooring to replace knocked down wall-12547394_949220831820701_29455138_n.jpg
How to replace one wall??? drklude Drywall & Plaster 23 10-25-2012 09:03 AM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
How do you replace the top plate on an exterior wall? Rickrzr Building & Construction 6 08-19-2010 10:39 PM
Crazy?....but how do I install hardwood flooring on wall yummy mummy Flooring 37 01-08-2009 05:19 PM
