Flipping Kitchen Cabinet Doors???? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-26-2014, 10:07 AM   #1
biggles's Avatar
flipping kitchen cabinet doors????
need to flip a couple of doors upper ones .SALICE/Mills Pride is stamped on the hinge.the left side is the door and cabinet is right side.it looked easy with phillip screws on that hinge,and done.they won't unscrew from the inside of the cabinet 1/4 turn the most...any trick here....there are pre drilled holes to flip them 180 degrees on the opposite side any help
Old 08-26-2014, 11:08 AM   #2
Rewards Points: 144
No reason they should not unscrew from the cabinet.Are you using the right size driver.Usually a #2.Try putting it in the screw and tapping it with a hammer.
If you have knobs or handles on the door the will be off after flipping the door.
mako1 is offline   Reply With Quote
Old 08-27-2014, 10:00 AM   #3
Rewards Points: 2,098
Originally Posted by biggles View Post
They won't unscrew from the inside of the cabinet 1/4 turn the most...any trick here....there are pre drilled holes to flip them 180 degrees on the opposite side any help.
Try removing the door first. Take the pressure off the inside hinge. Those inside hinges look like the type where you just reach behind the hinge and pull right off for easy removal of cabinet door. Then try removing the inside hinge. Depending on the type of hinge, there may be other screws once you remove the cabinet door. Just a suggestion.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
oh'mike (08-27-2014)
Old 08-28-2014, 08:39 AM   #4
Rewards Points: 2,412
Mills Pride were sold at homedepot. The factory is gone. You will not find replacement.
You may not be able to change the doors because of the pull knob. They are drilled and positioned left and right.
The two screws in the photo can not be removed. I tried and sheared the screws. The plate shown pops off with finger. Inside is adjust screw and hinge set screw. Set screw is the rear. If you loosen the set screw, the door will slide off. Hold the door.
Youtube should have some videos. Search for euro hinges.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
jmon (08-28-2014)
Sanding Swinging Door and Cabinet Doors...NEWBIE jmiza Windows and Doors 8 12-31-2012 06:21 PM
kitchen cabinet doors lawbm Kitchen & Bath Remodeling 1 11-20-2011 08:13 AM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
Kitchen cabinet doors jad Kitchen & Bath Remodeling 2 04-13-2010 08:35 AM
Replacing just the kitchen cabinet doors? imola ghost Remodeling 7 02-24-2010 11:03 AM
