Flashing Window Head Casing - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-23-2015, 11:58 PM   #1
Rewards Points: 59
Flashing window head casing
I am installing a couple of new construction vinyl windows with an integral flange. I am installing 5/4x4 wood casing all around the window.
The window flashing seems pretty straight forward except how to deal with the head casing. At first, I thought I would lap the house wrap over the top flange of the window and tape it with self-adhered tape. But then how do I get the z cap flashing that sits above the wood head trim under the house wrap? Hope that description makes some sense...
Thanks for any advice!
handyman923 is offline   Reply With Quote
Old 09-24-2015, 05:18 AM   #2
kwikfishron's Avatar
Rewards Points: 274
The housewrap goes over the top of both the flashing and the window flange.
kwikfishron is online now   Reply With Quote
Old 09-24-2015, 07:06 AM   #3
Rewards Points: 17,890
Concidered using PVC wood grain 1 X 4 lumber instead of wood?
No more rot, can be painted if needed.
Old 09-24-2015, 09:41 AM   #4
Rewards Points: 59
Thanks for the replies... So I basically slot the house wrap just above the trim?
I looked at pvc trim, but it seems cost prohibitive. I may end up using Hardi trim.
Old 09-24-2015, 04:05 PM   #5
Rewards Points: 274
[QUOTE=handyman923;2511041]So I basically slot the house wrap just above the trim?
That would be correct.
Basement Window Flashing CTSNicholas Windows and Doors 4 08-25-2015 10:28 PM
Flashing the bottom of a bump-out window to rigid foam? scadjacket Windows and Doors 6 08-15-2015 09:00 PM
Flashing a window with PVC trim Golfnut_NC Windows and Doors 13 01-02-2012 12:54 PM
Retrofit window flashing question dragondoom295 Building & Construction 1 09-06-2011 08:08 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
