Fixing Sun Faded Stain On Knotty Pine Tongue And Groove - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 11:18 AM   #1
Question
fixing sun faded stain on knotty pine tongue and groove
We have put up pine tongue and groove on all our walls and ceilings. Looks great but, when we took furniture out of one room, we found that one section of a wall was sun faded.
Sorry I meant to say We had NOTstained just put on 2 coats of polycrylic.
What I want or need is a way to fix this, don't want to take out two walls.
What is best product ex. (Formans with steel wool)?Any suggestions would be of help.
Parri R is offline   Reply With Quote
Old 01-20-2014, 11:57 AM   #2
Rewards Points: 1,466
I suggest you sand or use a paint stripper then sand paper down to bare wood on a test area next to that which isn't faded. When you believe it's about right try the polycrylic on the test area and go from the information you have there.
Sometimes good things take a little longer and in my opinion the phrase " I want it to match" should be stricken from the vocabulary.
Old 01-20-2014, 12:12 PM   #3
Rewards Points: 17,880
It the area that was not covered by the furniture that changed not the area behind it.
With the furniture gone it will now be exposed and will also fade to match if given some time.
Want it to match now then your facing having to redo the whole wall.
Clean first, light sanding, clean again and apply another coat of sealer.
Installing tongue and groove pine flooring whosmatt Flooring 1 12-24-2013 02:52 AM
Tongue and Groove Pine paneling Smoke Tools 2 10-21-2013 05:41 PM
Yellow Pine tongue n groove Porch creek07 Painting 4 07-03-2012 09:56 PM
milling own pine tongue and groove chulett General DIY Discussions 24 06-06-2011 09:58 PM
The pine tongue and groove has no brenda o General DIY Discussions 38 10-31-2009 12:13 PM
