Fireplace Venting - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2018, 04:52 PM   #1
Rewards Points: 125
Fireplace venting
All,
I am in the planning phase of re-modelling an older (~20 year-old) fireplace. I cut a hole in the drywall above the fireplace and took a picture of the fireplace from above and noticed a flexible duct (similar to a dryer vent) sticking out of the side of the fireplace and going through a hole in the platform that the fireplace is sat on. What is it?
Regards
Chris
spiragui is offline   Reply With Quote
Old 02-15-2018, 07:20 PM   #2
Rewards Points: 1,744
Re: Fireplace venting
That could be a fresh air intake, so your fireplace has fresh outside air to burn. That hose I believe would eventually go outside to a louvered opening. You may have another control in your fireplace to open and close this air supply, aside from the main flue.
If you have a basement look into the cantilever space below the fireplace and you might see where the hose goes.
ChuckF. is offline   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
spiragui (02-15-2018)
Old 02-15-2018, 07:53 PM   #3
Rewards Points: 125
Ah, right you are! It's a meshed opening under our deck. It needs a good clean too, good thing we hardly use our fire.
Chris
Gas Fireplace / Exhaust & Venting.. NorPlan HVAC 15 05-16-2016 01:31 PM
Gas Fireplace Insert Venting Question Koellert HVAC 9 01-09-2015 11:53 AM
Venting for NG direct vent fireplace in basement fubar79 HVAC 4 03-23-2011 12:18 PM
Venting fireplace? Suggestions??? gabel8 HVAC 1 10-06-2010 08:54 PM
Venting for Gas Fireplace Insert? MikeinBurien HVAC 7 11-18-2009 04:51 PM
