Finishing A Cinder Block Basement Fireplace - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-19-2017, 08:37 AM   #1
Rewards Points: 6
finishing a cinder block basement fireplace
I would like to finish the cinder block on a basement fireplace. I have thought of just painting it or putting on drywall.
If I put up drywall, how would I attach it. Furring strips?
If I paint , should I put on a skim coat of cement?
I would download a photo, but I don't know how...
Thanks, Burt
burt saxby is offline   Reply With Quote
Old 03-20-2017, 04:23 PM   #2
Rewards Points: 6
Re: finishing a cinder block basement fireplace
Here is a picture... Thanks everyone!!
Old 03-20-2017, 05:32 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
Its easier to attach via furring strips. Will you need to run any electrical in that wall?
Old 03-20-2017, 09:03 PM   #4
Registered User
Rewards Points: 526
----------------------------------Welcome to the forums!-----------------------
Code requires 12" from the flue liner to any combustibles (wood/plastic furring strips), IDK if yours meets one of the three exceptions or not, pages 8, 9/10; eg.; http://www2.iccsafe.org/states/virgi...Fireplaces.pdf
Check with local AHJ or Fire Marshall or the permit you need anyway... judging by the framing/drywall.
Gary
Old 03-21-2017, 06:18 AM   #5
Rewards Points: 6
Thank you. I will measure this weekend. I am sure the sides are 12 inches away from the flue, but not the front.
No wires will be used on these walls....
Todd
Water pipe to house. Do I check under cinder block ???? steve3847 Plumbing 10 12-29-2013 07:50 PM
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 08:26 AM
basement cinder block leaks iwannabeer General DIY Discussions 1 10-14-2011 12:08 PM
Filling basement cinder block for insulation. diy4life Building & Construction 8 11-25-2009 03:33 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
