Fiberock Underlayment - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-04-2016, 04:22 PM   #1
Rewards Points: 2
Fiberock underlayment
Remodeling older kitchen, got the floor down to old tongue and groove wood. Plan on putting down 4x4 sheets of Fiberock then ceramic tile. To adhere Fiberock to wood floor, can I just screw it down or is it best to use an adhesive between old wood floor and Fiberock?
Unclewally is offline   Reply With Quote
Old 04-04-2016, 04:39 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Re: Fiberock underlayment
Do they make it 4*4? All I see is 3*5. Needs to be set in thin set. Must be nailed or screwed with the thinset.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 04-04-2016, 08:27 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 748
Uncle Wally,
Hold everything there will ha. An old kitchen with old tongue and groove wood means 4-6" wide planks to me, and if I'm right, you can not install your Fiberock direct to that, or any other CBU for that matter. You need to first install plywood or OSB.
If you'd like some advice to make sure you're heading down the right path, let's start with you telling us how the framing is built. Size of the joists, spacing, unsupported span. see if you can figure out the species and grade of the joists and tell us if they're in good condition.
Yes, underlayment grade comes in both 4x4 and 3x5 in & ⅜ thickness.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
rjniles (04-05-2016)
Old 04-05-2016, 10:06 AM   #4
Breakin' Stuff
Rewards Points: 1,360
My advice, listen to JazMan. And I've learned that the cement board for under the tile is NOT structural in any way. It's counter intuitive, I know.
Bret86844 is offline   Reply With Quote
The Following User Says Thank You to Bret86844 For This Useful Post:
JazMan (04-06-2016)
Underlayment and toilet flange voodoochile Flooring 5 12-04-2015 07:44 PM
Roofing underlayment overlap jratlanta Roofing/Siding 6 02-28-2014 03:05 PM
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 02:38 PM
Underlayment question-- "extending" existing underlayment fastener and type cbrc5eric Flooring 9 06-01-2011 04:03 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
