Exterior Door Replacement - Rough Opening Smaller Than Specs - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-20-2015, 12:32 PM   #1
Rewards Points: 2
Exterior Door Replacement - rough opening smaller than specs
I have an exterior door I am replacing. When the old door is out, the rough opening will be 33.5" wide. A standard 32" door calls for 34.5. What can I do?
marklombardi is offline   Reply With Quote
Old 06-20-2015, 01:48 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Usually the rough is 2" wider than the door. If your jacks are exactly plumb you may get by with 1.5".
Otherwise widen the opening or buy a 30 inch door.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 06-21-2015, 08:34 PM   #3
Rewards Points: 454
Measure the jamb, its probably 331/2" you might be OK if everything is plumb, try to beat the door studs over, a 1/4" might be all you need. have you checked the height?
scottktmrider is offline   Reply With Quote
Old 06-30-2015, 11:14 PM   #4
Rewards Points: 2,452
Don't just beat on the studs. You may be weakening the header above or split/damage the studs, trim, esp where they meet the top and bottom plates. Maybe you can move about 1/8-1/4. Rest you will have to remove with a chisel and parts with a saw. Use cheap saw blade and saw through the nails. 1/2" deep at a time. Refasten the studs.
carpdad is offline   Reply With Quote
Tags
door , door frame , prehung. rough opening
Rough opening size Malcolm Building & Construction 2 06-10-2014 08:59 AM
Rough Door Opening of 48x80 can I put smaller door in? zmindyk Carpentry 12 10-24-2011 11:06 AM
exterior door rough opening jgcable Building & Construction 2 05-24-2011 07:08 AM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 06:43 PM
Replacement Windows Smaller Than Rough Opening stubits Remodeling 1 08-25-2010 06:19 AM
