Exterior Door Replacement Glass Inserts? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-16-2017, 11:26 PM   #1
Rewards Points: 28
Exterior door replacement glass inserts?
Where can you find just the inserts for exterior doors? Are they ridiculously priced!
Mcswain is offline   Reply With Quote
Old 07-16-2017, 11:42 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Exterior door replacement glass inserts?
Most Glass shops should have a supplier or they can fab one up.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 07-17-2017, 09:52 AM   #3
Rewards Points: 28
I asked the employee at allowed in "door" department. He said probably if had serial number and manufacturer. ???? Really? There standard sizes. Can you get me one or not lol
Old 07-17-2017, 10:38 AM   #4
Rewards Points: 4,110
Go to an actual glass shop, not a big box store.
Yes, these are going to be expensive - as someone who buys enough glass every year to get wholesale price from a manufacturer, I can tell you there's a lot of markup on glass.
stick\shift is offline   Reply With Quote
Old 07-17-2017, 10:56 AM   #5
Rewards Points: 28
Ugh..... I was wanting to get replacement figured be a lot cheaper. Prob cost as much as the slab w/glass!
Old 07-17-2017, 10:56 AM   #6
Rewards Points: 28
I used to work at a door shop! It's out of business or I'd be hooked up!
Old 07-17-2017, 08:17 PM   #7
Usually Confused
lenaitch's Avatar
Rewards Points: 2,038
They will be expensive largely because they have to use safety glass. I'm thinking there is less standardization than you think.
lenaitch is offline   Reply With Quote
Old 07-17-2017, 09:49 PM   #8
Rewards Points: 28
I used to build pre-hung interior doors and help build exterior doors with sidelines, transforms, etc. I'm pretty sure he half glasses fit half glass, half moon fits half moon etc. There could be some deviation I'm sure.
Replacing double pane french door glass inserts Double Windows and Doors 2 06-26-2012 08:59 AM
Double-hung window sash glass replacement teetee1 Windows and Doors 1 03-10-2012 11:21 AM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
Sliding Glass Door: Inserts or Replace? roztom Carpentry 6 07-20-2008 03:53 PM
