Extending Rake - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-19-2017, 06:54 AM   #1
Rewards Points: 4
Extending Rake
Here is my issue. The back wall of my house has no overhang on the gable wall. Rain flows over the edge of the roof down the wall. Despite caulking, the edge water is still getting behind the vinyl siding and causing issues inside.
Before going through and fixing the mildew problem in the wall I would like to fix the cause.
Is there a method of extending the Rake without having to re-shingle the roof? Ideally, I would like to extend the roof a foot overhang but that would mean having to reroof the house and that was just done before we moved in 5 years ago.
Is there any sort of gable end gutter I could install? Channel or drip edge that would help here?
dmmoelle is offline   Reply With Quote
Old 05-19-2017, 08:23 AM   #2
Rewards Points: 692
Re: Extending Rake
Can you post a picture?
JIMMIEM is offline   Reply With Quote
Old 05-19-2017, 08:39 AM   #3
Rewards Points: 5,810
Re: Extending Rake
As JIM asked, pictures would help.
Once we see what you have I suspect some rake trim set a bit higher will keep the water from getting behind the siding.
Was the siding added over the top of existing siding?
Bud
Bud9051 is offline   Reply With Quote
Old 05-22-2017, 08:19 PM   #4
Rewards Points: 4
Re: Extending Rake
Old 05-22-2017, 08:40 PM   #5
jlhaslip's Avatar
Rewards Points: 708
Re: Extending Rake
Removing the first set of shingles would be required to be effective.
Otherwise there are too many things to go wrong with not good results.
Sometimes it just doesn't pay to go the easy road.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-22-2017, 08:45 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 2,038
Re: Extending Rake
It seems kind of odd that rain would be running across the roof rather than down unless driven by wing. Kinda unconventional but would eavestrough and drip edge buy him some years?
lenaitch is offline   Reply With Quote
Old 05-22-2017, 09:29 PM   #7
Rewards Points: 17,890
Re: Extending Rake
No picture came up, need a few more post to post pictures there trying to keep scammers out.
Relying on caulking to keep water out is never a good idea, it always fails.
A properly done siding job does not need any caulking.
Pictures will tell us what we need to know.
Chunks of sod pulling up while raking (thatch rake)? Durt Ferguson Landscaping & Lawn Care 5 10-09-2015 09:27 PM
Rake trim issue sleseman Roofing/Siding 11 10-27-2013 05:37 PM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
Desperately need a bigger better thatch rake carl1864 Tools 2 09-12-2010 11:50 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
