Extend Header On Load Bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Daniel Holzman
Old 11-07-2016, 11:56 AM   #1
Rewards Points: 18
Extend header on load bearing wall
Hello,
This is a basement of a two story home. I have a door opening that is currently 36" wide with 3 2x8 header in a 2x6 framed wall and is load bearing.
I want to widen the doorway and make it 62" wide. I am planning on using the same 3 - 2x8 header for this span......sound ok?
I'm in Canada
projectpete19 is offline   Reply With Quote
Old 11-07-2016, 12:08 PM   #2
Civil Engineer
Rewards Points: 5,246
Re: Extend header on load bearing wall
You need to discuss this project with the building inspector. If your floor above has a design load of 40 psf, your factor of safety for a 62 inch opening with (3) 2x8 members may be below code requirements. Unfortunately I am not familiar with Canadian building code, my comments on factor of safety relate to commonly used US building codes.
MTN REMODEL LLC likes this.
Old 11-07-2016, 12:19 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 9,270
I agree with Daniel on this one.
Because that wall is 6" wide....good chance it's supporting a lot of weight above it.
Not worth taking chances.....talk to your inspector.
If it was me....what ever they said it needed to be with sawn lumber, I'd be using a PSL beam. But that's me.
ddawg16 is online now   Reply With Quote
Old 11-07-2016, 04:35 PM   #4
jlhaslip's Avatar
Rewards Points: 708
I have a copy of the CDN span Tables in a 2 page PDF, but it is larger than the Forum allows for uploads.
The rating of the Header will depend on the load resting upon it, which is a function of the joist length in this instance.
Can you measure the joist lengths on each side of that wall and post them here?
Thanks.
*EDIT*
Also, single story or two story home?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-07-2016, 05:03 PM   #5
Rewards Points: 18
Joist lengths are 11' on each side to the Center of load bearing wall....and it's a 2 storey
Joists are 2x8 16" on centrr
Old 11-07-2016, 07:05 PM   #6
jlhaslip's Avatar
Rewards Points: 708
Using 12 feet of supported Joists, it looks like a triple 2 x 8 header would work if it is defined as a "Beam" since it is actually a structural lintel holding both joists plus likely the second floor and roof. Use a double Jack under each end to bear the weight as a Beam rather than a Lintel and it should be good.
PM sent.
Old 11-07-2016, 07:11 PM   #7
Rewards Points: 18
PM sent.
Thanks for the info....it validates what I found on other spam tables as well
Old 11-08-2016, 06:26 AM   #8
Rewards Points: 18
Here is the building code for my area so it seems 62" opening will work if I read the tables right.
Old 11-08-2016, 09:44 AM   #9
JOATMON
ddawg16's Avatar
I mentioned it once before....
Instead of using 3 2x8's....I'd use either a gluelam or PSL beam. The cost is not really that much more....just a few $$ more. But that beam would be a lot stiffer....much less likely to ever bend. It will also fill the area much better since it's going to be the exact thickness you want.
3 2x8's is going to be 4 1/2" thick. You're 6x wall is 5.5. You're short an inch.
The PSL will the exact thickness you want. Makes drywalling easier.
And ditto on the double jack....or just use a 4x6 and nail from the king stud side.
Less chance of warping....and with no nails on the 'working' side, makes life a little easier trimming out.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Load Bearing Wall Header troyce1 Building & Construction 12 09-14-2012 06:00 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 11:29 AM
Replace 2x4 with Header on Load Bearing Wall HooKooDooKu Building & Construction 4 12-31-2009 11:21 PM
