Is This Excellent Workmanship? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-19-2016, 01:54 PM   #1
Rewards Points: 18
Is this excellent workmanship?
Tile shower pan was replaced with existing glass doors reinstalled.
Currently leaking water through the 1/4inch gap between the shower door sweep and tile ledge.
I was told this was excellent workmanship by the tile contractor.
He is suggesting that the glass company reinstalled doors incorrectly.
Thoughts?
amiconfused is offline   Reply With Quote
Old 04-19-2016, 01:58 PM   #2
Rewards Points: 18
Re: Is this excellent workmanship?
I'm trying to include pictures, but so far I am not allowed to.
Old 04-19-2016, 01:59 PM   #3
Rewards Points: 18
Here are pictures. Notice the drain.
Old 04-19-2016, 02:52 PM   #4
Rewards Points: 7,202
Put a level on the threshold under the door. Is the threshold level, sloped into the shower, sloped out of the shower ?
My threshold has a small slope into the shower, which I assume is the correct way. When I had the frameless glass door made and installed, they didn't want to put a sweep on the bottom -- said that not the way they normally did it. But I insisted, and the installed the bottom sweep. Sweep contacts the threshold firmly. It all works.
So you have a quarter inch gap between the sweep and the threshold? I am no expert, lets see what others say, but I think the sweep should be in contact with the threshold. Those extrusions they use for sweeps come in countless different sizes and profiles --- could easily be replaced with something bigger
SPS-1 is online now   Reply With Quote
Old 04-19-2016, 03:55 PM   #5
Rewards Points: 18
Threshold is not level, but the slope is very slight. I can take a picture if you like.
It's not significant enough to actually drain water, so the water just sits on the ledge and as more water runs down from the shower doors, it starts to drain out the gap on to my bathroom floor into huge puddles that need to be mopped up.
Old 04-19-2016, 04:11 PM   #6
Sloped which direction?
Old 04-19-2016, 04:14 PM   #7
Rewards Points: 18
Oh. Maybe it's not sloped at all.
Here:
Old 04-19-2016, 04:18 PM   #8
JUSTA MEMBER
Rewards Points: 3,586
If the drain area is an example of the contractors excellent workmanship, I question their vision.
There should be a sweep made with a seal that should contact the top of the tile, to seal it from a leak, see if the door company can supply one.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Windows on Wash (04-25-2016)
Old 04-19-2016, 04:24 PM   #9
Rewards Points: 18
In an email, the owner of the company told me this was "excellent workmanship", and he said he wouldn't fix it, informed me that he would sue me for slander if I left a negative review, and he would send me to collections if I don't pay by the end of the week (a total cost 60% more than the cost I authorized). I know there are unforeseen costs sometimes, but the hours billed don't match the hours onsite.
I'm having another contractor out today to tell me how much to fix. sigh.
Any suggestions for next steps?
Yes, they are licensed and bonded.
Old 04-19-2016, 04:27 PM   #10
Rewards Points: 18
Also, yes, I've had wonderful experiences with contractors in the past that were professional, honest, and did great work...so I feel like I picked the rotten apple in the bunch accidentally.
Old 04-19-2016, 04:29 PM   #11
Rewards Points: 18
Ed,
The door has a sweep.
Are you saying they can order an extra long sweep maybe?
Even if I fix that, the ledge still pools water instead of draining as it's not sloped.
Old 04-19-2016, 04:55 PM   #12
JUSTA MEMBER
I did a google search for SHOWER DOOR SWEEP, came up with one that was 1.5 inch by 36 inch long, for $23.00.
There were many more than that, so do go search to find more.
And If the gap is sealed the pooling on the slight slope threshold will be minimized.
ED
Old 04-19-2016, 04:59 PM   #13
Rewards Points: 1,754
Several things you should do.
1. Put together a file with estimate, and actual contract, and any existing communications you've had with the company.
2. Immediately start all additional communication via email, or text, and retain it so you will have proof of the owners failure to correct the problem.
3. Get a couple other companies to give you their written opinion, and a written opinion of what it will cost to rectify the poor installation.
4. File a small claims case against the company requesting they cover the cost to repair the poor installation.
5. Inform the company that you have filed a suit.
If you have all your paperwork, and documents from other professionals, showing that his work is substandard, you will win.
ktkelly is offline   Reply With Quote
Old 04-19-2016, 05:16 PM   #14
Property Mgt/Maint
Rewards Points: 6,370
from the last pic in post 7, I see no sweep at all,
and the tile work around the drain is crap,
They didn't take the time to cut the tiles with the correct
saw. They used their wet saw and tried to make hack out
a arc.
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
ChiTownPro (04-19-2016)
Old 04-19-2016, 06:01 PM   #15
Rewards Points: 18
I found a different sweep that will actually touch the ledge. So that fixes one of the issues.
New steps, concerns about the workmanship. Photos gregthec Concrete, Stone & Masonry 18 05-02-2016 04:58 PM
Excellent ant repellant! jenchip Pest Control 3 10-22-2014 12:49 AM
New Roof - Concern Over Seemingly Poor Workmanship cjakins Roofing/Siding 16 11-24-2009 06:38 AM
Excellent Tools & Excellent Tool Comapnies jamiedolan Tools 12 07-21-2009 03:44 PM
Contractor workmanship issues kfen Electrical 35 08-15-2008 11:37 PM
