Enclosing Furnace Ducts - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By TarheelTerp
  • 1 Post By jkk
Old 03-06-2018, 09:40 AM   #1
jkk
Rewards Points: 317
Enclosing furnace ducts
I posted this is the drywall section but now I think it's better suited for the remodel section.
Trying to enclose furnace ducting with drywall. When it was just a supply duct, I would have just screwed a 1/2" piece of drywall to the bottom of the 2x2 walls. With the circular return next to it, the span is now 26".
Would a 26" wide piece of 5/8" drywall sag?
If I have to , we can move the circular duct 2" away from the supply to allow installation of a middle support wall. Would prefer not to do that, to avoid extra work and keeping box as small as possible.
Thanks,
jkk is offline   Reply With Quote
Old 03-06-2018, 09:54 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,126
Re: Enclosing furnace ducts
Originally Posted by jkk View Post
Would a 26: wide piece of 5/8" drywall sag?
Yes it would.
to avoid extra work...
This is the reason behind a LOT of work getting redone.
Whatever else you do get a bucket of mastic and a chip brush.
Old 03-06-2018, 09:55 AM   #3
retired framer
Rewards Points: 18,634
We would have dropped a few more inches and run 2x4 on the flat between the drops walls. If you have the height I would just strap it below the 2x2 with 2x4 2 ft OC. That will also help prevent warping.
Old 03-06-2018, 09:57 AM   #4
jkk
Rewards Points: 317
? Why mastic and chip brush?
Old 03-06-2018, 09:59 AM   #5
jkk
Rewards Points: 317
Trying to save the height. I'm 6'4" and hate ducking in the basement. I'll probably move the round duct over, insert another 2x2 wall between the 2 ducts.
Old 03-06-2018, 10:11 AM   #6
retired framer
Add a 2x2 or 2x3 to the inside of the left side.
Old 03-06-2018, 10:26 AM   #7
Rewards Points: 2,866
Do you have the clearance to install a metal stiff leg between the two ducts than use a main beam as in the Dry wall metal grid system attached to the stiff legs. The stiff would be required every 4 ft.
ClarenceBauer is online now   Reply With Quote
Old 03-06-2018, 11:56 AM   #8
MarginallyQualified
Mike Milam likes this.
Old 03-06-2018, 01:15 PM   #9
jkk
Rewards Points: 317
Never used a metal grid system. Where can I learn about that?
Nealtw likes this.
Old 03-06-2018, 02:34 PM   #10
See if you can find a USG hand booklet.
Research dry wall metal grid system it is very much like an Acoustical but design for the attachment of dry wall. try this www.usg.com.
The reason i stated the use of stiff leg was because if you use hanger wire you will have a problem of the beam moving up when the screw contacts it.
ComfortMaker RPJ II furnace blinking 6 times stlengineer HVAC 14 12-24-2015 08:15 AM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
