Enclosed Carport For Garage.. Wall Removal Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-30-2017, 08:29 PM
Enclosed carport for garage.. Wall removal question
I have framed in my attached carport to make a garage. There was a small wall with two doors that I started removing. The trusses were running perpendicular to the wall. I saw no signs of this being a load bearing wallbother than that. It was on a concrete slab . When I started cutting with a Sawzall it never bound or anything. I don't see a sign of a header for support either. There is a span of 28' with only one 2x4 up top which I assume was for the wall that was there. It's only about 4' from the exterior wall which runs parallel. I checked the attic as there is a similar span through the dining room (older ranch home) and there are no beams or attic supports. I feel like I am ok. Any thoughts? Should I be concerned?
Enclosed carport for garage.. Wall removal question-14988724017501159965298_1498872456595.jpg   Enclosed carport for garage.. Wall removal question-14988724794421126618243_1498872494441.jpg
Blakeb is offline
Removing an Interior Wall Question prenger745 Building & Construction 11 04-08-2013 12:13 PM
Enclosed carport lonnie.seratt Building & Construction 1 10-04-2011 07:10 AM
Partition wall supporiting ceiling joists (recommendations for removal) afly007 Building & Construction 3 09-29-2011 10:57 AM
load bearing wall question mudpaws Carpentry 3 06-24-2011 09:39 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
