EMT In Crawlspace Vent - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-30-2017, 09:26 PM   #1
Rewards Points: 2
EMT in crawlspace vent
I want to get electrical from a crawlspace into an exterior wall in an addition we're adding to avoid running electrical through an attic that will be inaccessible after the drywall is up (vaulted ceiling truss). The foundation has a raised stem wall, so there is no rim joist that would allow access to drill up through the bottom plate. So the only place I can get electrical from the crawlspace to the wall is up through the vents in the raised stem wall as in this picture: . It is ok to have EMT so close to the outside? There is no joint in the EMT within 2 feet of the vent except for the one that will be inside the wall, so I there shouldn't be a moisture problem, but I don't know what the NEC or other codes might say about this.
drdugl is offline   Reply With Quote
Old 10-30-2017, 11:54 PM   #2
retired framer
Rewards Points: 18,478
Re: EMT in crawlspace vent
Try posting the photo again, they don't work on anyone's first post.
Nealtw is offline   Reply With Quote
Old 10-31-2017, 03:13 AM   #3
Rewards Points: 4,146
Nealtw
Right click on picture box, then click open in another tab. The picture will appear.
ron45 is offline   Reply With Quote
Old 11-03-2017, 10:52 PM   #4
Houston, I think we have an opening........
plumbing vent boilermaker27 Plumbing 5 09-26-2013 07:37 PM
Downdraft range vent exhaust placement problem Docman General DIY Discussions 2 08-02-2013 03:26 AM
The Edge Vent/Smart Vent and leafguard User123 Roofing/Siding 5 07-08-2013 10:31 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
