Easy Way To Fix This Countertop / Backsplash? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 06-27-2018, 07:36 PM   #1
Rewards Points: 16
Question
Easy way to fix this countertop / backsplash?
I've had handymen fix it twice but all the water gathers up there and destroys the paint. Looking for an easy fix that will last 2-5 years. Tile won't fit there ( 1.5" space to the wall ). I could buy backsplash but don't want to deal with trying to cut tile. Thought of using wood but not matter how I treat it I'm sure water will destroy it sooner than later. Can I just sand it and cover it with grout or something similar?
Easy way to fix this countertop / backsplash?-fullsizerender-2.jpg   Easy way to fix this countertop / backsplash?-img_4482.jpg   Easy way to fix this countertop / backsplash?-img_4484.jpg
Mustardeer is offline   Reply With Quote
Old 06-27-2018, 07:37 PM   #2
Rewards Points: 16
Re: Easy way to fix this countertop / backsplash?
By the way not trying to fix the sink nor the blue wall, just the disgusting mess around the sink.
Old 06-27-2018, 08:27 PM   #3
retired framer
Rewards Points: 18,838
Some handy man should have talked you into a new laminate counter top.
Likely would have been cheaper in time and money.
Old 06-27-2018, 08:53 PM   #4
Rewards Points: 16
So is a laminate counter top the easiest solution?
Old 06-27-2018, 08:54 PM   #5
Rewards Points: 16
What are a few other ways to remedy this situation?
Old 06-27-2018, 09:01 PM   #6
retired framer
How long is the counter, does it turn corners too?
Old 06-27-2018, 09:04 PM   #7
Rewards Points: 16
It's long but I'm not worried about the rest of it, just need to fix the area pictured. It's okay if it cuts off, not looking to win remodeling awards.
Old 06-27-2018, 09:08 PM   #8
retired framer
That's not how it works. you want one piece replacement that will last 20 or 30 years.
Others may have suggestions.
Old 06-27-2018, 09:15 PM   #9
Rewards Points: 16
I'll be out of here in 2 years. I'm buying a house. Just need a temp solution. Like I said I'm renting and having landlord fix this is not an option.
Nealtw likes this.
Old 06-28-2018, 04:57 AM   #10
Naildriver
chandler48's Avatar
Rewards Points: 3,684
Key word is "renting". Don't do anything to change the countertop, etc. Liability falls directly on your shoulders. Is the countertop painted?? What is it made of?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-28-2018, 05:50 AM   #11
Rewards Points: 16
Owners don't care I can do whatever I want. They won't sue me. Not sure what it's made of, I'm guessing pressed wood. I tried covering it up with white paint it lasted a few months. A few handymen repaired it with I'm guessing silicone it lasted like 3 months each time.
Old 06-28-2018, 06:50 AM   #12
Naildriver
chandler48's Avatar
Do you have it in writing?
They won't sue me
Don't bet your life savings on it.
All you can do is sand it down and keep painting it. To do it right will require the replacement of the countertop and reinstalling the old sink or a new one. $$ that you won't recover.
Larry......
Old 06-28-2018, 09:07 AM   #13
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,278
Need to chip out some rot first and then fill with epoxy.
Might last a bit longer, maybe a couple of years.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 06-28-2018, 09:21 AM   #14
JUSTA MEMBER
Rewards Points: 3,654
Remove all the old rot, then get a can of auto-body filler ( BONDO), and form a new backsplash, and countertop.
Sand it smooth, and Krylon the thing.
Get a permission from the landlord, and go for it.
Otherwise, get a scratch and dent laminate countertop from a BOX store, and replace the countertop.
My locals sell a " filler" countertop for cheap, and although it is usually an odd color, it is quite well built for a laminate countertop.
As a renter you are liable for anything done by you to the premises, so definitely get permission FIRST.
ED
Nealtw likes this.
de-nagorg is online now   Reply With Quote
Old 06-28-2018, 04:45 PM   #15
Rewards Points: 16
ED
This is what I was looking for. Thanks so much. Hopefully you know what you're talking about.
Tags
backsplash , countertop , kitchen , tile and grout
Best caulk for granite countertop and backsplash tile NaveenM Kitchen & Bath Remodeling 4 03-04-2018 12:44 AM
Backsplash nightmares (cabinet related) Toml Kitchen & Bath Remodeling 6 12-07-2017 02:49 PM
Remove laminate backsplash georgioltd Remodeling 4 10-17-2012 06:56 AM
DIY easy countertop help beautysensei General DIY Discussions 1 05-29-2012 05:54 PM
countertop/ backsplash butterhead Carpentry 5 04-13-2012 01:57 PM
