Durock Question Of Install - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-06-2015, 04:02 PM   #1
durock question of install
Hello, quick question on what's the order to correctly install durock for tile for shower wall, here is what I've figured this far
1- studs-plastic sheeting- durock- tile with thinset
2- studs- durock- waterproof coating - tile with thinset
3- studs- plastic sheeting - durock- waterproof coating - tile with thinset
I've heard if I double waterproof the shower surround, I will trap moisture and cause mold
imboard is offline   Reply With Quote
Old 09-06-2015, 08:20 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 748
Hi,
You shouldn't do #3 for the reason you mention.
#1 is acceptable, but the plastic or tarpaper on the studs is just a vapor retarder, makes nothing waterproof and the CBU will still get wet if the grout develops some hairline cracks and vapor is still in play.
I recommend #2 cuz nothing behind the two + coats of liquid membrane or a sheet membrane such as Kerdi will ever get wet. The shower will be watertight and the shower will dry faster after use.
Plus if you use Kerdi, you can use regular drywall if you want.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 09-07-2015, 08:53 PM   #3
Rewards Points: 32
I just recently did this myself remodeling a bathroom and did option #2- studs- durock- waterproof coating - tile with thinset.
Make sure the waterproof coating is on thick, I had to do a couple coats using a cheap 4" roller to build it up on the durock. Also, make sure you use fiberglass mesh tape or the cement board mesh tape (same thing?) to do your joints.
shark_bait is offline   Reply With Quote
OSB to durock install acfrqflyer Flooring 26 01-05-2014 04:32 PM
Durock / insert mudding question Trucon01 Kitchen & Bath Remodeling 2 04-04-2013 10:34 AM
Durock question REXAMUS Drywall & Plaster 3 04-02-2013 04:36 PM
Hydronic Towel warmer install question bigbluedude HVAC 5 02-13-2010 07:02 AM
culture stone install question raven27 Building & Construction 4 11-02-2009 10:31 AM
