Drywall Installation Info - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By chandler48
  • 2 Post By Gregsoldtruck79
  • 1 Post By myhouse1
  • 2 Post By ClarenceBauer
  • 1 Post By mark sr
Old 06-12-2018, 03:35 PM   #1
Rewards Points: 6
drywall installation info
Hi I am new hear so here it is I have a drywall that's putting up my drywall and he missed measured and the drywall 3" off the floor and he says he is going to leave unless I pay him more as this is ASTM standards so I have always thought it was supposed to be a 1/2" to 3/4" anyone know of a link to what ASTM standards are I cant find it on a general search thanks in advance
myhouse1 is offline   Reply With Quote
Old 06-12-2018, 04:01 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,692
Re: drywall installation info
I don't think it has too much to do with ASTM "standards" as it does with being dumb. 3"? You're kidding, right? Got pictures? What was his plan for the base? If your walls are 8', then two sheets would leave about 1/2" at the bottom after the top piece was jammed against the ceiling rock. Why did he cut it?
joecaption likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-12-2018, 04:04 PM   #3
Rewards Points: 2,878
https://www.usg.com/content/dam/USG_...-en.pdf#page=2
I am not a drywall guy but yiu may want to co over this handbook and check the details.
ClarenceBauer is offline   Reply With Quote
Old 06-12-2018, 06:32 PM   #4
Rewards Points: 1,406
I could not find any specifications for the wallboard bottom gap min/max requirements on Clarence linked manual . So I went to USG thinking the OP could demand the board at least be installed to the manufacturer's specifications. No help on their manual either about above the floor clearance measurements.
Common sense dictates unless the buildings engineered drawings are specifying to leave the board up 3 in. from the floor, so that say... a specialty trim is to be installed that needs to fasten directly to the open studs, then there really is no excuse for such a installation of wallboard IMO. So he would have to take me to court to get paid and that won't happen because the install is flat out wrong.
https://www.usg.com/content/dam/USG_...de-en-J371.pdf
joecaption and myhouse1 like this.
Gregsoldtruck79 is offline   Reply With Quote
Old 06-12-2018, 07:00 PM   #5
Rewards Points: 6
Its a log home with 8'3" walls he didn't cut it he miss measured and instead of getting the bigger drywall he just put it up now he's crying for more money he's not going to get but dumber yet he was to put green board in bathrooms said something when didn't see any green there so he goes and puts up the white made take that down and do it again
Old 06-12-2018, 07:19 PM   #6
Naildriver
chandler48's Avatar
Real logs and you are covering them with sheetrock??? He should have ordered 54" sheetrock to accommodate the difference in height. He's a dimwit. He needs to take a hike.
Larry......
Old 06-12-2018, 08:31 PM   #7
Rewards Points: 6
Not covering them they are the inside walls
chandler48 likes this.
Old 06-12-2018, 09:07 PM   #8
Rewards Points: 17,896
If he even owns a tape measure he would have known this going in and ordered wider drywall for less seams.
Not your issue, it's his.
If he wanted to skip out on ordering the wider drywall and just add that narrow strip (which is a pain to tape) then it should be at no cost to you.
The seam would be hidden by the baseboard.
Old 06-12-2018, 09:14 PM   #9
ASTM Standards do not cover Installation of drywall the ASTM is material
Testing Standards.
One of my old USG handbooks dated 1987 on page # 138 states " Interrupt wood floor and ceiling plates with 1/2 inch Gap."
Also on page # 333 it states " To control external stresses partitions and other gypsum construction must be relieved from frame work. These recommendations provide for 1/4" relief and are for normal situations."
All detail drawings in my Plaster & Drywall Systems Manual dated 1976 show the 1/4" gap at dissimilar materials.
I would also call your local fire inspector and ask what would be their understanding as for fire rating?
Old 06-13-2018, 05:20 AM   #10
retired painter
Rewards Points: 1,432
Since he bid the job wrong that is on him not you! Before the advent of 54" drywall the ripper was put in the middle so you didn't have to bend over to tape/finish. Your checkbook is your best bargaining chip. Don't pay until he finishes the job - he'll come around and finish the job.
1/2"above the floor is the norm for drywall.
MTN REMODEL LLC likes this.
mark sr is offline   Reply With Quote
Old 06-16-2018, 01:44 AM   #11
Rewards Points: 202
ASTM standards organization supplier for a wide range of materials, products, systems and services.
MasterPipe is offline   Reply With Quote
Tags
drywall
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 08:42 AM
Drywall installation question Mark Harvey Building & Construction 1 10-25-2012 06:31 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Drywall installation ron e Drywall & Plaster 1 05-29-2011 09:05 PM
drywall installation peggyjayp Drywall & Plaster 4 08-13-2008 07:09 AM
