Drywall To Hardie Backer Transition - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Str8AheadInc
Old 06-06-2017, 10:36 AM   #1
Rewards Points: 2
Drywall to Hardie Backer transition
I am remodeling a bathroom and am tile the tube surround. I demoed the existing tile to find the framing does not butt up to the bathtub. When I initially tried to install the hardie backer, it didn't cover the lip of the tub. I furred the wall out so that the backer board would cover the tub lip. This in turn caused about a 1/2 inch difference between the drywall transition and the backer board (backer board sticking out further). I am trying to figure out how to properly tile the tub surround so that the transition looks professional. Does anyone have suggestions on how to go about this transition?
ctremont is offline   Reply With Quote
Old 06-06-2017, 05:17 PM   #2
Pro-Am Construction Slave
Rewards Points: 6
Re: Drywall to Hardie Backer transition
Could use tile with a quarter round edge to go over the hump. That was what was originally in the bathroom I'm finishing.
Big Earl is offline   Reply With Quote
Old 07-18-2017, 01:49 AM   #3
Professional
Rewards Points: 188
The tile backer does not get installed over the lip of the tiling flange. Instead the tile backer should be installed 1/8" above the flange and then the area between is filled with hot mud. This prevents wicking. You then would not have the current issue. I recommend pulling your furring strips and trying this, then you can just tape the joint at the backer/drywall interface. Good luck with your project!
Nealtw likes this.
Str8AheadInc is offline   Reply With Quote
Old 07-18-2017, 06:41 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,624
I find it better to rest my cbu on top of the flange, leaving the gap below with the vapor barrier over the flange, cut off flush to the curve. That keeps the cbu flat on your studs and your tile will jump the 3/8" or so gap between the tub and the cbu. It totally prevents wicking, far better than trying to fill the gap with anything. I seldom caulk the tub-to-tile joint too, as it allows any water to drain, preventing another cleaning area with poorly applied or inferior sealant. No mold, no ugly, no water wicking.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
taping transition from CB to drywall owenpga Remodeling 2 02-24-2017 08:33 AM
Joining 1/2" backer board to 3/4" drywall prestoham Kitchen & Bath Remodeling 2 02-01-2012 10:31 PM
where tile backer meets drywall rtoni Building & Construction 11 01-07-2011 09:05 AM
Cut Hardie Backer too short Scotto1234 Flooring 0 03-29-2010 08:38 PM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
