DRICORE....good/bad? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 12:44 PM   #1
Hello,
I am looking to refinish my little more then half my basement which is around 600 sqf. I do have a subpump that has never turn. The bucket where the subpump is alwas dry also(have had the house for 2 years). This doesn't mean i will not get water. So far i have waterproofed (so they say) with the walls with Ames Blue Max and going to put 2inch foam insulation against walls. I am very concerened aobut water even though i haven't got any in basement and have had estimates to but french drains along the inside of basement for over 5000. Lot of money for maybe will get water.
Thinking about using DriCore for subfloor and putting my 2x4 walls on the dricore just in case any water gets in basement it will flow under the subfloor to my subpump which is lowest point of basement. Good or bad idea ? thoughts on dricore subfloor?
have reviewed many reviews on this topic just can seem to get a right answer.
I am a newbie to this forum....Thanks in advance.
thenewkid is offline   Reply With Quote
Old 05-25-2013, 08:59 PM   #2
Rewards Points: 512
600sqft of dricore is expensive. i'd look into putting platon down http://retail.armtec.com/en-ca/Produ...r-Options.aspx and you can put tongue and groove plywood on top making dricore for a fraction of the price and installing it in a fraction of the time. also i'd build your walls first and then butt your subfloor to the walls. as you know water in a basement is always a threat and its not if water will enter but when. So if water does get in and you have to pull up even a section of the subfloor it would be a huge pain trying to pull it out from under your walls.
princelake is offline   Reply With Quote
Old 05-25-2013, 09:31 PM   #3
Rewards Points: 2,800
The purpose of Dricore is to allow moisture to find its way out but not to allow water to flow underneath.
Correct all wet basement problems before installing Dricore.
More than 3/16 inch of water on the floor underneath will find its way up and then under the plastic edges of the Dricore cleats and cause warping and mold.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
The Following User Says Thank You to AllanJ For This Useful Post:
Windows on Wash (05-27-2013)
Old 05-25-2013, 09:35 PM   #4
Thank u for info
Old 05-25-2013, 10:32 PM   #5
Registered User
Rewards Points: 526
Where are you located?
Gary
Old 05-25-2013, 10:37 PM   #6
Gary
Located in MA
Old 05-28-2013, 12:14 AM   #7
Registered User
Rewards Points: 526
I agree with princelake, above, There are many other barriers that equalize the vapor pressure (and don't use OSB), Enkadrain, DeltaFL, etc., even foamboard; http://www.buildingscience.com/docum...g-your-basment
Figure 10*F warmer, 6' down; http://www.epa.gov/athens/learn2mode...enrys_map.html
Moisture should not be allowed to find its way around the membrane/dricore (seal the edges), it should stop gas/air to equalize the vapor drive pressure, Fig.3; http://www.buildingscience.com/docum...ms?full_view=1
Do you need to insulate the slab? Is dricore enough? Page 58--- ;http://www.buildingscience.com/docum...sure-guideline
Gary
Old 05-28-2013, 06:09 AM   #8
Rewards Points: 512
only benefit to dricore being made out of osb is when you basement does fill with water the osb soaks up the water swells up and floats as one unit. i've been to basement floods where theres 5-6" of water under the dricore its floating and all the peoples contents are dry. but for minor leaks osb is bad and will soak it up and you wont even notice it rotting and molding under your feet until it gets bad and starts to smell. pay insurance and make sure you have a good plan and store things in rubber totes and other stuff up off the floor.
Old 05-28-2013, 12:31 PM   #9
If i am using dricore it would cost me 1.25 psf with coupon at lowes/homedepot and the DMX1 step would cost me 1.09 psf......
http://www.spycor.com/DMX_Subfloor_f...ete_p/dmx1.htm
Still trying to decide which one is better for me........ have looked at so many post gets me confused
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 05:02 PM
Finishing Basement: DRIcore and walls? oppie2005 Remodeling 11 02-24-2012 05:00 PM
dricore in basement beech Flooring 1 08-18-2010 08:41 AM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 08:45 AM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
