Double Barn Doors - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-26-2018, 07:30 AM   #1
Rewards Points: 2
Double Barn Doors
Hi! We are installing a double barn door. We are just about finished but for some reason the doors don't match up when closed. They touch together at the bottom but not at the top which leaves a gap. We checked and checked again the level of the hardware and it's level.
Any suggestions on how to fix this?
suzyvee is offline   Reply With Quote
Old 04-26-2018, 08:34 AM   #2
Rewards Points: 944
Re: Double Barn Doors
If it's not the track, then it must be the hangars. With the standard kits they have for interior barn doors, there is no easy adjustment. I would check each door with a level and figure out if one or the other is out of whack. Then take the offending door down and adjust the hangars. You'll probably have to enlarge the bolt holes to give yourself a little wriggle room.
Marson is offline   Reply With Quote
Old 04-26-2018, 09:03 AM   #3
Guapo
Rewards Points: 11,950
The doors aren't plum.
Guap0_ is offline   Reply With Quote
Old 04-26-2018, 02:24 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Most are adjustable via cam action of the wheels, whose axles are concentric.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-26-2018, 03:37 PM   #5
Rewards Points: 1,406
Gregsoldtruck79 is offline   Reply With Quote
Customed Milled Doors - Advice Needed about Errors Rubespur General DIY Discussions 7 03-23-2018 07:31 AM
Ensuring Strength for 1-Lite Doors Rubespur Windows and Doors 4 03-09-2018 06:19 AM
Hss anybody heard of using slab doors as window? Is this idea ridiculous? kimballfount Building & Construction 21 10-30-2017 10:26 PM
Hanging double french doors without disturbing current molding harpua728 Carpentry 23 07-17-2015 02:13 PM
double interior doors/ gap jkee Carpentry 2 10-05-2010 07:08 AM
