Door Slab Replacement Installation Issues. - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-01-2015, 08:30 PM   #1
Rewards Points: 126
Door slab replacement installation issues.
Hello,
I am installing replacement door slabs. When I put in this slab, there was a large gap at the top of the door on the opposite side of the doorknob. How do I fix this?
I've already tried moving the wood on the door frame, but I had trouble prying it out at the corner and broke a piece.
Suggestions welcome
jeffdoesrepairs is offline   Reply With Quote
Old 11-02-2015, 07:30 AM   #2
Rewards Points: 17,890
Most likely the jamb is not plumb on that side.
Simple fix is to remove the stop molding, and sand the paint line smooth, prime and paint then reinstall the molding.
Old 11-02-2015, 11:04 AM   #3
Rewards Points: 426
Also if you are trying to remove that stop molding you have to start at the bottom.
KC_Jones is offline   Reply With Quote
Old 11-02-2015, 01:45 PM   #4
Rewards Points: 126
I had to cut the side of the door that has the hinges on it. Due to the guide I was using, it may not be a perfectly straight cut where one of the hinges is. It will be hard to tell which hinge is the problem hinge, and I wouldn't know how to fix it. Does the fix change with this new information?
Old 11-02-2015, 03:47 PM   #5
Rewards Points: 5,348
You need to fix the hinge side issue before dealing with the strike side.
Ron
B. Franklin 1759
Old 11-03-2015, 05:41 AM   #6
Rewards Points: 14
Yeah.. what you said is right. Fixing the hinge side issue should be the first step before dealing with the strike side.
eunicedlawson is offline   Reply With Quote
The Following User Says Thank You to eunicedlawson For This Useful Post:
Ron6519 (11-03-2015)
Old 11-03-2015, 06:25 AM   #7
ZTMAN's Avatar
Rewards Points: 278
Check the stop for plum, check the door slab for plum, when closed. I would assume the slab is not plum. If you cut the hing side of the door, my guess is you will have to move the bottom hinge out about 1/16 of an inch and the top hinge in 1/8 of an inch (hinge on the jamb, not the door. If you move the hing on the door side, top hinge out, bottom hinge in)
ZTMAN is offline   Reply With Quote
Old 11-19-2015, 03:58 AM   #8
Start at the bottom and consider the hinges at first.
christopherjhar is offline   Reply With Quote
Cold walls, humidity issues, frost issues with exterior doors Howitzer Insulation 46 12-14-2014 09:56 AM
New Roof Install - Problems and issues. cjaustin81 Roofing/Siding 110 09-13-2014 08:44 PM
Discovery work or not? Replacement of panel tied to installation of new circuits reggie ho Electrical 11 08-08-2014 11:31 PM
Post-torsion spring replacement issues mikevC General DIY Discussions 7 07-11-2014 07:00 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
