Does Bathroom Fan Vent Duct Need Insulation When In A Heated Space? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-05-2014, 10:03 AM   #1
Rewards Points: 397
Does bathroom fan vent duct need insulation when in a heated space?
I'm putting in a new exhaust fan in the lower level and found out the previous fan did not have exhaust vents going to the outside, which I want to correct.
My only choice is to run the vent through the joist bay about 22 feet through our laundry room and out the exterior wall. I want to use rigid 4" ducts for this, but since they will be in a heated area ductwork, do I need to insulate the ducts? I'm in frigid Minnesota. I know this would help a bit with my home heating bill, but wouldn't that cause more condensation in the vent because the duct work would remain colder on the inside?
Is it better to not insulate the duct when going through a heated space to the outside?
Studly is offline   Reply With Quote
Old 03-05-2014, 10:45 AM   #2
Rewards Points: 170
Generally they are only insulated when ran through unheated spaces, such as attics here in Wisconsin.
diyer111 is offline   Reply With Quote
Old 03-05-2014, 12:34 PM   #3
Rewards Points: 38
Many cities in Minnesota now require us to insulate the last 3' of exhaust duct prior to exiting the structure. Rather than worry about if the city I am in requires it or not we purchase 10' long duct insulation, cut it in half and insulate the last 5' on every install. I recommend you insulate at least the 3'.
SHR Plumber is offline   Reply With Quote
Old 03-05-2014, 02:50 PM   #4
Rewards Points: 766
I would insulate as far in as possible to keep the cold air from coming in through the duct and escaping into your heated area.
Buy the insulated ducting at the big box stores and pull the flexi line out and insert the rigid ducting.
B
Beepster is offline   Reply With Quote
Old 03-05-2014, 05:34 PM   #5
Rewards Points: 1,466
Check the exhaust air for dew point temperature and that will answer your question. Worst case possibly - showering. Second worse case - hot steaming tub of water. A steamed mirror is a good indicator of those conditions.
If the pipe is 70F and dew point of the exhaust air is 69 there will be condensation. If the dew point is greater and the pipe temp. less than those numbers, condensation naturally gets worse.
Old 03-05-2014, 08:55 PM   #6
Registered User
Rewards Points: 526
Another vote for insulate it all. Cold air from exterior travels to the fan where it is stopped (sort of) by the fan damper. Someone please invent a damper- fan or exterior hood- that is weather-stripped to seal properly (with low resistance). I would buy one over a standard one, every time! Listen-up, you aluminum benders from other lands...
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
ben's plumbing (03-05-2014)
Old 03-05-2014, 09:36 PM   #7
Rewards Points: 582
we insulate the whole run.... ben sr
Old 04-04-2014, 05:32 PM   #8
Dark Knight
Streeter1981's Avatar
Rewards Points: 18
Send a message via AIM to Streeter1981
I would think insulating the whole run would be easy enough to do. I ran mine through an uninsulated space and didn't insulate. And do wish I would have. I might have to redo that
Streeter1981 is offline   Reply With Quote
Old 04-04-2014, 11:30 PM   #9
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Installing a ventilation fan in my upstairs bathroom is quickly making it up my to-do list.
Could anyone post links to what they would recommend.
Conditioned Crawl Space Insulation LuckyFoot15 Insulation 4 09-30-2012 01:35 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 07:52 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
