Do I Need To Lay Down Luan If Laying Laminate Wood? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-22-2014, 01:32 PM   #1
Question
Do I need to lay down Luan if laying laminate wood?
From upstate NY-
I have heard by many, different opinions. I am going to be laying a laminate wood floor (8mm with 2mm pad already on the boards) in my kitchen. I was originally told you need to lay down luan(am I spelling that right?) first. Now Im being told I dont have to.
aaronsangel is offline   Reply With Quote
Old 05-22-2014, 01:39 PM   #2
Jb1234's Avatar
Rewards Points: 87
What is the subfloor made of already?
Jb1234 is offline   Reply With Quote
Old 05-22-2014, 01:42 PM   #3
Rewards Points: 17,912
All laminate needs is a flat smooth surface to go over.
Old 06-17-2014, 12:06 PM   #4
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
luan board is not proper flooring underlayment.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 06-17-2014, 06:26 PM   #5
Contractor
If the subfloor is OSB, Plywood, or even SMOOTH PROPERLY FINISHED concrete, you do not need luan. However, if going over concrete you must first assess moisture content, then from there you can decide if laminate is a good choice for the flooring. Also install a vapor barrier. Now as far as ATTACHED underlayment goes, its usually a cheaply made padding, and often times people choose to lay down an additional underlaymant. It helps to keep the floor from sounding "hollow" and also improves the sound dampening. Ive seen in many homes, after ripping up carpet, vinyl etc, they already had Luan on top of the existing OSB or plywood. So the short answer is NO you as a rule do NOT need to lay down Luan.
steveinNEPA is offline   Reply With Quote
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
Wood laminate sealer? Keninpoway Flooring 1 06-19-2012 06:38 AM
Wood Laminate in the Kitchen quesenbarrett Flooring 4 03-21-2011 01:58 PM
A little help with laying laminate pete0403 Flooring 13 01-09-2011 06:53 PM
Swift Lock laminate wood flooring on steps? Leche4evr Flooring 1 08-29-2009 12:49 PM
