Do I Need Inspection After New Stair Installation In Pittsburgh, PA - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 03-19-2018, 09:19 PM   #16
Rewards Points: 14
Re: Do I Need Inspection After New Stair Installation in Pittsburgh, PA
I'll reply to my own question - it's a stupid question
de-nagorg likes this.
dpdiy is offline   Reply With Quote
Old 03-19-2018, 09:43 PM   #17
JUSTA MEMBER
Rewards Points: 3,672
If a tyke was visiting you, and fell from the very top step, to the floor underneath, the effect would be the same as if a grown up fell off a 4 story building.
So no way is it O K.
This is the reason the balusters need to be closer together, so a tyke cannot crawl between them.
Better to DO IT RIGHT THE FIRST TIME , than to need to redo it.
ED
dpdiy likes this.
de-nagorg is offline   Reply With Quote
Old 03-19-2018, 09:49 PM   #18
Rewards Points: 14
This is a redo - contractor already messed it up the first time.
Old 03-20-2018, 08:05 AM   #19
Guapo
Rewards Points: 11,950
Removing the railing completely is worse than leaving the balusters at 7". The idea of the 4" baluster space is so a child can't put his head between them. The fix that I gave you in post #10 is the way to solve the problem. It's a one day job.
Guap0_ is offline   Reply With Quote
Old 03-20-2018, 01:36 PM   #20
Oso954's Avatar
Rewards Points: 1,818
I don't know if home inspectors who work for buyers would see the difference, w/o actually measuring it.
You don’t try to see the difference in riser height. You feel it in your feet. When it feels weird, then the buyers inspector starts measuring to prove it/obtain the greatest difference for his report.
If the small and large just over the 3/8 and spread out, the inspector might not catch it. But with the reported 1 inch difference, an inspector would notice it if he is used to using stairs.
When the difference between heights is too large it becomes a tripping or stumbling hazard. A face first fall is bad enough when you are going up. Stumbling forward and rolling downstairs can be fatal.
An actual permit inspector will be more stringent in his inspection of the stairs than a buyers home inspector.
Oso954 is offline   Reply With Quote
Old 03-20-2018, 05:31 PM   #21
Guapo
It's up to the OP now. I already said what I would do to resolve it.
Old 03-20-2018, 08:49 PM   #22
Rewards Points: 1,222
It should be noted here that many older houses do not have steps up to code and never could due to space restrictions. Some will be grandfathered and codes will not apply.
CrazyGuy is offline   Reply With Quote
Tags
building code , inspection , permit , pittsburgh
Repair Stair Stringer sunshine54 Flooring 2 11-27-2011 11:06 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Stair Tread And Riser Installation Speckert General DIY Discussions 3 11-19-2008 02:33 AM
State Vehicle Inspection - ARGGH Leah Frances Off Topic 14 04-05-2008 12:59 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
