Ditra Install Over Drylok Basement Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-22-2017, 07:51 PM   #1
Rewards Points: 2
Ditra install over drylok basement floor
Quick question on ditra install in a basement. I have a concrete slab floor that structurally is in good shape. The downside is that there is drylok installed and some of it is flaking off. Is it possible to install ditra over the drylok after cleaning up all the loose areas? Planning on tiling about 300sf in this area. Thanks in advance!
Judd1980 is offline   Reply With Quote
Old 01-22-2017, 09:39 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Ditra install over drylok basement floor
That's not a very good plan Judd. I think you should do it right and remove the paint.
Now, let's see. Drylok is intended where water in coming in the walls. **I don't recall, but I don't think it's supposed to be used on floors in the first place. I might be wrong. And of course, don't forget to do all the moisture tests required once you see bare concrete.
You need one of these; http://www.diamabrush.com/hand%20tool.htm
Jaz
** I was wrong, they do have one for floors. BUT I think it's never a good idea to paint floors. Stain yes, if you know you'll never want to bond anything to it again. Too late in this case however.....
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Basement Bathroom floor gottjas Flooring 1 07-22-2014 12:04 AM
Replacing basement floor questions strategery Concrete, Stone & Masonry 3 07-12-2014 07:05 PM
Question About Basement Floor Drains Mozart Plumbing 3 12-05-2010 02:19 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 05:06 PM
