Direct Mount Vs. Drop Ceiling: Basement ? - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-22-2017, 02:19 PM   #1
Rewards Points: 2
Direct mount vs. drop ceiling: basement ?
Finishing my small basement ... 16' x 16'.
I am liking a direct install ceiling system, rather than drop ceiling.
I like the extra headroom and it seems easy to install.
Anyone have experience doing this? Advice?
Thanks,
Rob
NRrob is offline   Reply With Quote
Old 10-22-2017, 02:41 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,612
Re: Direct mount vs. drop ceiling: basement ?
How much ceiling height do you have, now, floor to joists? The minimum you would want would be 7'6" or so. The taller, the better, of course. One thing to consider is what is above. Do you have plumbing and electrical that may need access sooner or later. Drop ceiling will give total access, but at a height sacrifice.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-22-2017, 02:47 PM   #3
Rewards Points: 5,770
If you don't have sufficient height another option, there is a thread here somewhere, you could paint the joists and everything up there. Some examples look very good and you gain a lot of height. Plus, probably less expensive.
Here are some pictures:
https://www.google.com/search?q=pain...HVqlCpQQ7AkIMA
Did a search and here is the previous thread:
http://www.diychatroom.com/f15/help-...sement-442602/
Bud
Bud9051 is offline   Reply With Quote
Question about basement ceiling tiles Susana89 General DIY Discussions 7 05-15-2015 12:46 PM
Smoke Detector in Drop Ceiling Hiro Remodeling 16 09-28-2013 03:41 PM
Basement Ceiling OhioDon Building & Construction 9 08-09-2010 01:33 PM
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 09:12 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
