Desperate For A Fix For My Stair Railing Requirement - Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 07-21-2018, 10:50 AM   #31
Rewards Points: 64
Re: Desperate for a fix for my stair railing requirement
I should have mentioned to get the post to fall in the right place on this staircase the second (upper) tread and riser need to be notched into which really isnít the end of the world. The orange block your using to show the size of the post should fall approximately, but not quite, inside the blue tape, itís hard to exactly tell you where from the pics. To finish the cavity produced to house the post to an acceptable professional look requires some skill, if it was easy everyone would be doing it. Iíve installed railings for over twenty years this really isnít that big of a deal. On a wooden staircase using whatís called a double gooseneck would get you from the first line of flight to the second. There are over the post systems for the handrail that keep the rail continuous that would look good with this application. Best of luck finding a competent installer.
Itrim is offline   Reply With Quote
Old 07-25-2018, 01:45 PM   #32
Rewards Points: 4,178
Take the post and run it from the floor up through the the stair to the ceiling right where the orange square is. This will serve the safety purpose plus give the strength needed for the railing.
My opinion.
It will look like the post is structural for the staircase as well.
You will be able to use...................
ron45 is offline   Reply With Quote
Deck stair railing issue? RETALS Building & Construction 17 10-11-2017 12:42 PM
Stair railing install. gramps4 Building & Construction 15 01-19-2017 04:41 AM
Need some advice on stair balusters and railing tonyg1 Building & Construction 12 08-30-2011 06:01 PM
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 05:54 PM
PVC Stair railing DIY_user Building & Construction 1 10-26-2009 07:59 AM
