Damaged Sheathing - Use Insulating Foam Sealant Before Fiberglass Bats? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-22-2019, 06:12 PM   #1
Rewards Points: 180
Damaged sheathing - use insulating foam sealant before fiberglass bats?
Remodeling a room with two exterior walls (corner room, ground floor, on concrete), and had to repair some of the framing (moisture, termites). Bottom plates replaced and all the damaged studs were sistered with new studs. I want to seal things up before installing fiberglass bats.
Some of the sheathing is damaged (this is exterior gypsum, which apparently was popular in the 60's). These are the worst spots:
There is a brick veneer outside this sheathing, so taking down the brick and replacing the sheathing is not practical.
Should I just fill this in with insulating foam sealant, such as Great Stuff Big Gap Filler?
As far as blocking air intrusion in tiny gaps, should I use insulating foam sealant such as Great Stuff Gaps and Cracks where the sheathing meets the bottom plates?
Or how about where the bottom plates meet the concrete (a termite shield was laid down between bottom plate and concrete)?
Lastly, up top, there are gaps between the sheathing and framing. This was never insulated with fiberglass.
Here's a closeup:
Should I leave it alone, or should I place some fiberglass insulation in that top gap? Maybe the bottom gap could get Big Gap insulating foam?
jbrah is offline   Reply With Quote
Old 07-22-2019, 06:19 PM   #2
Rewards Points: 180
Re: Damaged sheathing - use insulating foam sealant before fiberglass bats?
After dealing with blocking air intrusion, the next issue is laying down fiberglass bats. Because many of the studs were sistered, the stud bays are no longer 14-1/2" wide. Most are now 13" wide, and a couple are 11-1/2" wide (stud bays next to window where both sides of the bay were sistered).
I'll have to cut down the bats for the 11-1/2" bays. Is it worth the effort to trim the bats down for the 13" bays?
Given all the new studs and potential for thermal bridging, I'll put up foam board and then drywall on top of that, so that the foam breaks the thermal bridge.
Old 07-22-2019, 07:09 PM   #3
Property Mgt/Maint
Rewards Points: 6,368
You are on the right track. Spray foam what you can. Let set for a day and trim anything needed.
Regarding cutting down fiberglass. Yes you should. What I do is remove the paper, cut the fiber glass to fit, then staple the full sheet of paper back over the studs.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 07-24-2019, 01:29 PM   #4
Rewards Points: 484
I would use a two-part foam such as this:
https://www.homedepot.com/p/Touch-n-...2200/204962748
It will effectively provide an air seal but equally important it will double the R value of the bay. Glass bats when installed have been tested and shown to provide half their rated R value in real world installations. Even an inch of spray foam will add 3 points to the R value for the wall insulation.
It works well for irregular spaces and I used it with a bathroom remodel where I put in blocking for future attachment of hand rails and so did not have a continuous bay the length of the studs.
Calson is offline   Reply With Quote
Old 07-24-2019, 05:43 PM   #5
Property Mgt/Maint
I have never really heard good things about these DIY foam spray kits. Reading the reviews there are plenty of folks that gave it a 5 star, but I always read the bad ones first. And plenty folks have consistency issues, rated coverage issues, nozzles clogging etc. It just seams a little pricey with a good possibility of problems for my taste. Sounds like you had success.
