Cutting Door Trim On Crooked Walls And Close Doors - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-27-2015, 03:42 PM   #1
Rewards Points: 310
Cutting door trim on crooked walls and close doors
Any one have any tips for getting two pieces of door trim together in a corner like this? I was thinking running a 45 in the corner on both edges unless they make something for it?
Aslo any tips for ripping a door trim piece for a door that's close to a crooked wall? If I rip it straight there is a large gap in the middle. I need to just cut it with a circ saw i guess?
Cutting door trim on crooked walls and close doors-photo-aug-25-9-55-46-pm.jpg   Cutting door trim on crooked walls and close doors-photo-aug-25-9-55-40-pm.jpg
bhollehday is offline   Reply With Quote
Old 08-27-2015, 03:47 PM   #2
Rewards Points: 5,348
You must be really good with a circular saw to rip a 7 foot. 45 degree angle. I'd use a table saw with a fence.
How wide are those spaces?
Ron
B. Franklin 1759
Old 08-27-2015, 03:54 PM   #3
Rewards Points: 310
Your confused. Ive got two situations. One with two close doors (1.5" from each other but my door trim around the house is a little over 2"), which ill rip with a fence at a 45 im thinking. And another that needs to be ripped, but the wall is crooked. So the middle needs more meat than the top or bottom. So I was looking for tips or tricks, but maybe just ripping it straight as close as you can get it and then filling in with silicone is the best?
Old 08-27-2015, 04:35 PM   #4
The crooked wall solution is simple You scribe the molding using a compass. It will pencil the irregularities onto the molding. You tube should have a video. Usually a jig saw is good for this.
Use a latex, not silicone caulk to fill the gaps. Assuming you're painting.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
bhollehday (08-27-2015)
Old 08-27-2015, 05:01 PM   #5
Rewards Points: 310
Exactly what i was looking for!! Your awesome man Found the videos and ill give that a try witha jig saw I suppose (need to buy one) or maybe a careful circ haha
Now about those tight door trim corners. I assume best thing to do is cut a 45 on the ends that they meet? And use caulking to clean it up? When do you use silicone caulking? Latex is the printable and water cleanup stuff?
Old 08-27-2015, 06:29 PM   #6
Retired Moderator
Rewards Points: 7,174
The corner trims ---you are right--miter them----make a sample before you cut the final trim----
Old 08-27-2015, 11:36 PM   #7
You use silicone in areas that will not be painted. Bathrooms, kitchens. On the exterior of the house.
Just do a search for, "silicone caulking uses"
Latex is paintable/water cleanup.
Ron
B. Franklin 1759
Old 08-28-2015, 06:08 AM   #8
Civil Engineer
Rewards Points: 5,246
For the miter corners, the easiest way to get a good fit is to cut all three pieces, assemble on the ground, install the entire trim set as a unit. Then you don't have to fill the miters. You may need to shave part of the trim after installation, usually easily done with a plane or by sanding.
Old 08-28-2015, 06:22 AM   #9
Rewards Points: 6,873
I suggest a table saw as a better safer option. I can't imagine achieving and accuracy with a hand held saw,
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Walls bowing out in large room hoffmandirt Building & Construction 8 07-14-2015 07:01 AM
How close can i build walls to my furnace? hello18 HVAC 14 02-02-2012 05:32 PM
close in opening between roof/rafters and side walls of cabin Gracie Building & Construction 4 08-15-2010 09:15 PM
Before I close walls: hard wiring under cabinet lighting with Romex. jws3 Electrical 6 08-29-2009 12:24 PM
Cutting close to walls... scheenstra Tools 5 01-30-2008 08:06 AM
