Cutting Concrete For A Roll Up Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-10-2015, 07:56 PM   #1
Solutions (handyman)
Rewards Points: 462
cutting concrete for a roll up door
We have been asked to install an 8' x 8' door in a warehouse. The walls are concrete blocks stacked one above the other (not staggerd like bricks). The walls are aproximately 20' high and the trusses are about six feet apart. Our concern is if we cut through the wall, do we require a header or some other support for the above cement wall? There is a man door at the spot where the new door is to be installed and it appears as if it has some structural frame work. Is a header required or is there an alternative? If a header is suggested, how best to install it into the concrete blocks?
Sorry, no pictures.
Mark Harvey is offline   Reply With Quote
Old 01-10-2015, 08:46 PM   #2
Rewards Points: 392
Yes, it'll require some kind of head support. You should consult a structural engineer for this work as well.
rustyjames is offline   Reply With Quote
Cutting a hole in a slat door brucem609 Carpentry 9 11-27-2018 09:08 AM
Roll up Garage door / Coiling door beachfront71 Building & Construction 3 02-11-2014 10:19 AM
Need advice about entrance concrete door sill Earlybird Concrete, Stone & Masonry 11 04-19-2013 10:02 AM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
had garage door installed and concrete is unlevel!Help dwillis Flooring 8 04-20-2009 07:07 PM
