Curbless Shower Bathroom Build In This Old House - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 04-25-2019, 01:34 PM   #16
Rewards Points: 368
Re: Curbless Shower Bathroom Build in This Old House
@Nealtw
here is a picture of what I am Trying to do.
plumbing vents, toilet, shower - Yellow
framing - red
pocket door - violet
Curbless Shower Bathroom Build in This Old House-556393d1555514174-curbless-shower-bathroom-build-old-house-1.1-1-.jpg
JPeters is offline   Reply With Quote
Old 04-25-2019, 02:02 PM   #17
retired framer
Rewards Points: 4,966
Originally Posted by JPeters View Post
@Nealtw
framing - red
I would put it on the end with the shower head and you never knock stuff off the shelf with your elbow.
MaineLL and JPeters like this.
Do not use flat bottom gables with scissor trusses.
Old 04-25-2019, 03:06 PM   #18
Rewards Points: 368
With The 2x6 wall I'm Sure I could make a Niche and get the valve and the rain shower head etc behind it.
Old 04-25-2019, 03:11 PM   #19
retired framer
Or go around it.
JPeters likes this.
Old 04-29-2019, 10:59 AM   #20
Rewards Points: 368
Arrow
Sunday Free time update. @Nealtw You win! Relocate of the niche will happen
MaineLL and Nealtw like this.
Old 05-22-2019, 12:35 PM   #21
Rewards Points: 906
I do not see any blocking for adding hand or grab bars in the future. Bars are seldom in 16" or 32" lengths and the studs are not likely to be where you want a grab bar end connection in any case.
R Value of glass insulation with 2x4 studs is about R-2 and the best way to get more insulating value is to use a 2-part foam instead which provides more than 3x the insulating value and is easily applied to small sections as with bathroom framing.
If you are using a shower with jets and a hand spray it is a good idea to have the plumbing done to create a pressure balancing loop.
JPeters likes this.
Calson is offline   Reply With Quote
Old 05-22-2019, 01:13 PM   #22
Rewards Points: 368
@Calson
Have you done any Kerdi pans? I'm looking for info on a Kerdi pan and Hardi board walls.
Old 06-25-2019, 02:04 PM   #23
Rewards Points: 252
You could make your own shower pan, drop the sub floor and pack a pre slope pan to the drain's weep holes. Waterproof it with a pan liner liquid waterproofing membrane. Detail the corners first with something like eternabond tape. Heres a visual aid.
Lowered sub floor.
Pre slope pan to drain weep system
Wrap all transitions with crack suppression (eternabond tape, or similar)
Place eternabond tape over weep/drain cut holes for drain flange bolts
Apply liquid waterproofing
Now you're ready to pack your shower pan over it, if you ever have a leak with the shower pan theres a back up (no leaky leaky)
lug-nuts is offline   Reply With Quote
Old 06-25-2019, 02:08 PM   #24
Rewards Points: 252
Repeat all the above steps, slope pan to drain. Detail corners, apply liquid waterproofing.
Install drain, if linear drain pack after pan has a cured a day
Then waterproof entire floor
JPeters likes this.
The Following User Says Thank You to lug-nuts For This Useful Post:
JPeters (07-15-2019)
Old 06-25-2019, 02:12 PM   #25
Rewards Points: 252
Finish walls with hardi backer, or other material, and waterproof that. I installed 30# roofing felt behind my shower walls and layed it over the waterproofing in the corners like a shingle for watershed. Also leave walls about 1/2" above pan so water doesnt wick up.
JPeters likes this.
Old 06-25-2019, 02:14 PM   #26
Rewards Points: 252
Everything slopes to the drain. I have about 1/16" per foot on the bathroom floor and 1/4" per foot in the shower. I also installed a left and right shower screen so I dont really have much water that gets out of the shower area.
JPeters likes this.
Old 06-25-2019, 02:31 PM   #27
Rewards Points: 252
Yes, I removed all drywall materials from the shower surround. Everything is durock in the shower.
JPeters likes this.
Old 07-03-2019, 02:46 PM   #28
Rewards Points: 6
I like the window becoming the shower niche! That'll be real nice!
JPeters likes this.
StGRemodeling is offline   Reply With Quote
Old 08-13-2019, 12:47 PM   #29
Rewards Points: 368
This is what I'm planning on doing for the floor in the master bath
Old 09-04-2019, 01:22 PM   #30
Rewards Points: 380
Will you consider to use 1/2" Kerdi board instead of Hardi board for the wall? It's full 2'x4' panel. Light and easy to cut. You just need to apply Kerdi bands at board seams and screws. You will add in additional R-2 of insulation value and will make a shower enclosure more comfortable.
Itís an approved backing for Kerdi band to provide waterproofing at wall and Kerdi pan intersection
This way you would be mixing two systems of waterproofing - RedGuard and Kerdi witch is not tested, warranted or recommended by both manufacturers.
This is what I did for my master bathroom - minus the curb in your case.
tdisss is offline   Reply With Quote
Bathroom shower re-tile, pan redo BrandonD Kitchen & Bath Remodeling 0 08-24-2015 08:58 AM
Does this quote to build my bathroom shower seem too cheap? Joe Link Kitchen & Bath Remodeling 11 03-04-2015 10:49 AM
1930's house (old world charm) bathroom remodel ohman Kitchen & Bath Remodeling 17 11-06-2012 02:01 PM
curbless shower disaster- code compliance?? ck99 Flooring 7 08-31-2011 12:21 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
