Curbless Shower Bathroom Build In This Old House - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 04-17-2019, 11:16 AM   #1
Rewards Points: 368
Thumbs up
Curbless Shower Bathroom Build in This Old House
Hey everyone,
If you have noticed I have been asking a TON of questions and have soaked in just enough to start the process of a Kerdi bathroom.
I have removed a 16ft closet and intend on making that the exterior wall of the bathroom as well as the particle underlayment and to date have the T&G out and the plumbing and electrical moved. I will be ready for the walls and the shower specifically in the next weeks to come.
Check out the Pics! Cheers
Curbless Shower Bathroom Build in This Old House-.jpg   Curbless Shower Bathroom Build in This Old House-1.1.jpg   Curbless Shower Bathroom Build in This Old House-4.jpg
JPeters is offline   Reply With Quote
Old 04-17-2019, 11:18 AM   #2
Rewards Points: 368
Re: Curbless Shower Bathroom Build in This Old House
Now that I have the rest of the stuff out of the way!
Old 04-17-2019, 11:28 AM   #3
retired framer
Rewards Points: 4,926
How bouncy is that floor?
So is the plan to lower the shower floor to the level of the beams?
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 04-17-2019, 01:34 PM   #4
Rewards Points: 368
Arrow
Neal,
This thing was a damn bounce house After I took the closet wall out.
I crawled under the house and added a few pier pours and supports.
The remaining boards that I cut out end half way on to the beam. Letting one complete 4x8 - 1 1/8" sheet of plywood sit over the beams.
Also I added 2x6 brackets 12" O.C. for more support.
MAYBE: I should add another pier pours under the 2x6 and cross support them with a 4x8? (Probably OVERKILL... Idk.) What do you think?
  • I removed 5/8" underlayment and 1 1/2" subfloor = - 2 1/8"
    Add 1 1/8" Plywood and the KERDI pan 1 1/8" + 1 1/4" = 2 3/8"
Now that should put me a 1/4" above the subfloor and sheeting in the rest of the room. When I add the 1/4" Ditra Heat to the rest of the bathroom I should be FLUSH FLUSH!
HOW BOUT' DAT??
Another Project....
Nealtw likes this.
Old 04-17-2019, 01:35 PM   #5
Rewards Points: 368
If only I could upload video clips on here....
The window in the pic will become the shower niche.
What you think?
Old 04-17-2019, 02:33 PM   #6
retired framer
What you think?
A niche in the exterior wall?
Old 04-17-2019, 02:35 PM   #7
Rewards Points: 368
Yeah!..... Is that a bad idea?
Old 04-17-2019, 02:38 PM   #8
retired framer
Insulation?
Old 04-17-2019, 02:49 PM   #9
Rewards Points: 368
Insulation?
Honestly... The shower Niche will be in a 4'x 8" space in the area of the current window. I was not going to install insulation because I would loose my depth.
However! The Boss (GF) and I where talking and when I start to reside the house I was going to look into adding exterior insulation under the siding......
Old 04-17-2019, 02:54 PM   #10
Rewards Points: 368
Here is the working drawing.
Old 04-17-2019, 02:59 PM   #11
retired framer
Then I would frame out the wall 1 1/2" and add an 1 12/" foam to the back of the niche.
JPeters likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
JPeters (04-17-2019)
Old 04-24-2019, 05:24 PM   #12
Rewards Points: 368
Arrow
Got more done Last night..
Should be able to get the floor sheeted. Then stand walls.
Kerdi is on hold. JUST until I have it all framed up.
Next adventure frame wall s for pocket doors!
Curbless Shower Bathroom Build in This Old House-20190422_182346.jpg   Curbless Shower Bathroom Build in This Old House-20190423_190750.jpg   Curbless Shower Bathroom Build in This Old House-20190423_190832.jpg
Nealtw likes this.
Old 04-24-2019, 05:25 PM   #13
Rewards Points: 368
what do you thin about 1/4 rigid?
Old 04-24-2019, 05:40 PM   #14
retired framer
I think it has an R value of 1, less than a window. How do you like frozen shampoo.
MaineLL and JPeters like this.
JPeters (04-24-2019)
Old 04-24-2019, 05:53 PM   #15
Rewards Points: 368
IDK if you can tell in the picture.... I can defiantly deal with some frozen shampoo... and its getting easier and easier each year!
Bathroom shower re-tile, pan redo BrandonD Kitchen & Bath Remodeling 0 08-24-2015 08:58 AM
Does this quote to build my bathroom shower seem too cheap? Joe Link Kitchen & Bath Remodeling 11 03-04-2015 10:49 AM
1930's house (old world charm) bathroom remodel ohman Kitchen & Bath Remodeling 17 11-06-2012 02:01 PM
curbless shower disaster- code compliance?? ck99 Flooring 7 08-31-2011 12:21 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
