Crown Molding Obstacle - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-03-2019, 07:54 PM   #1
Rewards Points: 256
Crown molding obstacle
Any suggestions for this obstacle? I am installing 38 spring angle crown molding.
Jamesonc is offline   Reply With Quote
Old 05-04-2019, 08:02 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,676
Re: Crown molding obstacle
Do a return at the obstacle and move forward with another return on the other side if necessary.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Jamesonc (05-04-2019)
Old 05-04-2019, 08:56 AM   #3
Rewards Points: 256
Yeah, that is probably a more sane thing to do. I was considering removing the cabinet door, popping off the face frame and shortening both of them.
Old 05-04-2019, 09:44 AM   #4
Rewards Points: 334
How tall is the crown? If it fits between the ceiling and cabinet door, do as chandler48 says. If it is taller than the space, can you cut the door down?
Tymbo is offline   Reply With Quote
Old 05-04-2019, 06:24 PM   #5
hkstroud's Avatar
Rewards Points: 5,824
First I would call the obstacle a protrusion. I can't tell from the photo how far the protrusion sticks out from the wall. Looks to be about an inch or two.
The "correct" way would be to make an inside miter where the wall meets the protrusion then make an outside miter at the outer corner of the protrusion. However, cutting a piece crown short enough to fit the side of the protrusion would be extremely difficult if not impossible.
Suggestion;
Hold a piece of crown up to the ceiling at the proper angle next to the protrusion. Mark the end of the crown along the outer edge of the protrusion. Cut a 6" long notch in the bottom edge of the crown at the angle marked on the end. Hold that piece of notched crown up to see how it looks.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 05-04-2019, 06:30 PM   #6
retired framer
Rewards Points: 18,784
You might shorten the door and fill in the frame so you can come out around the frame.
Do not use flat bottom gables with scissor trusses.
Tags
38 spring angle , crown molding , obstacle
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
Crown Molding (tray ceiling) Butt/End Miter Cut Problem HTFreak Carpentry 5 03-09-2016 08:31 AM
Attaching Crown Molding To Frameless Kitchen Cabinets Fire4Effect Carpentry 12 06-23-2015 01:41 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
