Covering Sagging Ceiling Drywall - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-25-2017, 08:03 PM   #1
Rewards Points: 4
Covering sagging ceiling drywall
The ceilings thru out my house are sagging and I'm planning on redoing them. The plan is to take 1x4's and screw them to the joists over the existing drywall. My question is if I use 16 inch centers can I get a way with using 1/2 drywall or do I still need to use 5/8's. Any help will be greatly appreciated.
Josh222 is offline   Reply With Quote
Old 03-25-2017, 08:44 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,050
Re: Covering sagging ceiling drywall
I think the question at issue might be what is causing the sagging... could it be your framing.... and you'll be adding alot of dead laod.
5/8 is nice... it is stronger and spans better especially accross unculled difficult frameing.... but it's heavyier.
You might get away with a good sheetrock crew., bunch of shims, and 3/8.
Depends on what is sagging.
Good luck
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Josh222 (03-25-2017)
Old 03-25-2017, 09:47 PM   #3
Rewards Points: 4
MTN, its the drywall. Original builder used 1/2 rock on 2ft centers. As for the framing it seems pretty solid.
Old 03-27-2017, 07:23 AM   #4
Rewards Points: 2,458
16" oc is the norm for 1/2" drywall. As long as your joists can take the added weight, you can use 5/8 directly on the 24" span joists - no 1x needed. Check the joist span charts for deadload cap and spans/spacing. Unused attic ceiling joists are set for 10 ft/lb, but check the numbers. I think that is what I read on 24" oc framing houses. I would make stress relief cuts in the middle of drywall sags so that they'd be easier to push up with new drywall. For a whole house, I'd rent or buy drywall lift.
carpdad is offline   Reply With Quote
Old 04-02-2017, 06:54 PM   #5
Professional
Rewards Points: 188
You should definitely use 5/8" for 24o.c. spacing plus it meets fire code for ceilings. Once you pull down the old rock you can get an idea of what going on and how to plane in the new rock if necessary. I've done it many times but each situation is different.
Str8AheadInc is offline   Reply With Quote
Tags
ceiling , drywall , remodel
Currently have drywall on ceiling - can I attach 2x2 and a 2nd ceiling DanDaMan Drywall & Plaster 2 03-06-2017 02:16 PM
Is your drywall ceiling Cracking or Sagging? Checkout this Drywall Repair Tip Sir MixAlot Drywall & Plaster 0 11-05-2016 02:45 PM
covering drywall swirls on a ceiling rlewis Painting 16 08-22-2011 07:50 PM
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
