Countertop Epoxy Second Flood Coat - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-27-2016, 10:27 PM   #1
Rewards Points: 4
countertop epoxy second flood coat
Hi everyone. I've been reading posts on this site for a while, but i just registered so hopefully this community can help me solve my problem.
So... I just used varathane bar and table top finish on a countertop. Thing is I ran out of epoxy without covering the entire surface with a thick enough layer. I could could not get my hands on more of the stuff until now. The surface is now cured (it's been MORE than 48hres). Some parts are a little wavy and the edges are not properly coated. I want to know the process and surface preparation needed to apply a second flood coat. Do i need to lightly sand the surface to ensure a "mechanical bond" ? If I do so, will the next coat bring back the smooth shiny glass finish ? I've read about it, but always with other brands of clear epoxy coating, nothing about the varathane brand. Can I just pour another coat as it is now, meaning no sanding or buffing ? I tried to call and write to varathane(rust-o-leum), but no luck, nobody answers....
Thank you for any tips and advice !!
alexCL is offline   Reply With Quote
Old 09-28-2016, 09:17 AM   #2
Rewards Points: 4,106
Re: countertop epoxy second flood coat
What does Varathane say about this? Without any guidance from them, I would be inclined to scuff the surface with sandpaper before the next pour (removing the sanding dust, of course).
stick\shift is offline   Reply With Quote
Old 09-28-2016, 09:35 AM   #3
Rewards Points: 4
like i said.....no answer on their part.
Old 09-28-2016, 12:09 PM   #4
Ah, sorry - you did say that at the end of your question and I missed it.
Urgent need decision on 3rd coat gloss oil poly on heringbone red oak 9*2.25 floor mailuser3000 Flooring 0 07-28-2016 01:42 AM
Building and Finishing Epoxy Countertop for Kitchen onikonor Kitchen & Bath Remodeling 3 04-22-2013 01:25 PM
Stucco: Is it better to use 1 coat of of finish coat throughout or 3 coat system? psubaron Building & Construction 5 10-06-2011 07:48 AM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 03:55 PM
