Changing Out A Spiral Staircase??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-20-2018, 12:06 PM   #1
Rewards Points: 36
Changing out a spiral staircase???
So we bought a home with a metal spiral staircase and thought we would like it. We are finding some problems associated with it, like hauling things up or down it.
I would like to replace it with perhaps some platforms and straight stairs. With the information provided, do you think it would be possible?
My thoughts are perhaps a couple steps from the top and a small platform. Turn right and a couple more steps to another platform, turn right and longer stairs to the basement floor. Not sure if I have enough space to do that all.
The basement height is about 6' 10" finished
***Seems the photos aren't uploading. The album of the stair photos can be found here: https://photos.app.goo.gl/tVcUbH6SAtQyoBe39
hankejp is offline   Reply With Quote
Old 12-20-2018, 12:25 PM   #2
retired framer
Rewards Points: 18,584
Re: Changing out a spiral staircase???
That will be a big job, the floor would have to be restructures from below to make the hole bigger. Or you would have to add a bearing wall with footing below the basement floor.
You mentioned a landing. stairs are 36" wide and a landing is 36" long.
Measure the height from floor to floor
Replacing Spiral Staircase Floridahome Building & Construction 4 01-17-2011 06:26 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Spiral staircase possible with 20" x 21" opening? t_bunson Building & Construction 12 09-09-2008 06:18 PM
Spiral staircase questions NateHanson Building & Construction 3 01-20-2008 08:49 PM
