Center Wall Removal - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By de-nagorg
  • 1 Post By stevem3321
  • 1 Post By MTN REMODEL LLC
Old 02-17-2018, 09:49 AM   #1
Rewards Points: 4
Center wall removal
Good morning!
I have engineered trusses that run front to back in my house. The total distance from front to back is 24'. There is a center wall between the kitchen and living room that we want to remove. This wall is sitting under a splice in the bottom chord of the truss. The splice is there by design and has the proper mending plates. I am thinking that this center wall maybe slightly bearing because of this splice and by removing it will cause deflection in the bottom cord of the truss causing the drywall to crack. Has anyone had any success in properly removing this wall without causing deflection? I was thinking of possibly running a beam across the top of the bottom cord and then fastening the bottom cord to the beam. I am also open to other ideas. Thank you in advance!
stevem3321 is offline   Reply With Quote
Old 02-17-2018, 09:55 AM   #2
JUSTA MEMBER
Rewards Points: 3,638
Re: Center wall removal
Would a post under the area interfere with your plans?
Maybe twin columns on both sides a few feet apart.
It's best to consult a structural engineer, before taking out any wall, just to be safe.
ED
Gregsoldtruck79 likes this.
de-nagorg is online now   Reply With Quote
Old 02-17-2018, 10:00 AM   #3
Rewards Points: 4
Thanks, Ed.
We are thinking of that as a solution, but would love to have this area wide open. I would definitely need a structural engineer do some drawings before I pulled permits.
de-nagorg likes this.
Old 02-17-2018, 10:29 AM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
Your idea may work.... but trusses are really complicated eng issues.....and you are correct that you'll need to consult an engineer.
You probably don't have the original truss engineering drawing and stamp.... to see if they were originally eng'd for a full unsupported span.
MTN REMODEL LLC is offline   Reply With Quote
Old 02-18-2018, 09:52 PM   #5
retired framer
Rewards Points: 18,776
Take picture or draw something and visit a truss company a tri bearing truss is easy to see for anyone with experience.
Questions on Construction of my House: Built in 1980's, questioning structural design ejumps Building & Construction 4 03-05-2016 05:55 PM
wall removal... load bearing? interesting find jaxm211 Remodeling 6 08-07-2015 08:53 AM
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Wall Removal 1stclasso Building & Construction 4 02-12-2011 10:08 PM
