Cedar Siding And Window Replacement - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-14-2018, 09:22 PM   #1
Rewards Points: 181
Cedar siding and window replacement
What is the proper way to replace a window on a house with cedar siding? The cedar siding butts right up against the old window. I know I have to cut siding around the window to remove the old unit and its nailing fin. How do you finish the installation of the new unit and what would be the best way to trim out the window? Thank you
bcbud3 is offline   Reply With Quote
Old 08-14-2018, 10:37 PM   #2
Rewards Points: 17,890
Re: Cedar siding and window replacement
Please post a picture inside and out so we can see what your seeing.
Why do they need to be replaced?
Old 08-15-2018, 07:42 PM   #3
Rewards Points: 181
The windows were single paned aluminum and are now double paned vinyl. Both old and new windows had installations flanges on them.
Installing Replacement Window and Existing Wood Siding Trooper0999 Windows and Doors 2 05-19-2014 08:51 AM
Help Installing replacement window with Z-bar djstepanich Windows and Doors 7 03-02-2014 02:09 PM
Installing a new window, cedar siding foam sheating dirtmcgirt Remodeling 2 12-19-2012 03:38 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
