Cedar Plank Bathroom 😩 - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Yodaman
  • 1 Post By ryansdiydad
Old 07-05-2019, 05:45 PM   #1
My house is 100+ years old and it has this horrible cedar plank bathroom that I can no longer stand looking for at. It goes around all 4 walls about 4.5 feet up from the floor and the one angled ceiling has it up and across the ceiling. The walls behind it are plaster and look to be falling apart. Without ripping all of the planks off the wall, can I just fill in the gaps and sand it smooth? The cedar is rough in texture and just obnoxious. Any help or suggestions would be appreciated.
jmarsac is offline   Reply With Quote
Old 07-05-2019, 06:17 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,660
Re: Cedar Plank Bathroom 😩
Now that you have one post under your belt you can probably post pictures. Use the "Go Advanced" button below your next post and go to "Manage Attachments" THat way we can see what you see.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-05-2019, 06:33 PM   #3
Property Mgt/Maint
Rewards Points: 6,374
Not likely. If you are thinking drywall mud, it will just crack. Maybe even fall out.
You might consider skinning the walls with a thin drywall first. It would require less tape and mud.
Nealtw likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 07-05-2019, 10:13 PM   #4
Rewards Points: 4,212
Maybe.
https://www.homedepot.com/p/DAP-128-...E&gclsrc=aw.ds
ron45 is offline   Reply With Quote
Old 07-06-2019, 04:27 PM   #5
Rewards Points: 1,514
+1 for drywall over the plank.. I used 1/4 to cover a room full of pine and it worked out perfectly...
Yodaman likes this.
ryansdiydad is offline   Reply With Quote
