Casing Trim Installation Technique - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-18-2015, 02:57 AM   #1
Casing trim installation technique
I am replacing all of the trim in our house with wider molding than was there previously. The installation is going very slowly and someone has suggested to me that my technique is to blame and that certain tricks exist which -- apparently -- I have no knowledge of. The problem is that the walls had been wallpapered and the wallpaper curls up along the edge of the previous trim. Under these curled up edges there is a buildup of wallpaper paste such that the wallpaper edge forms a hard ridge which in some places exceeds 1/4" high and which my wider casing trim must now span while still lying flat. Also, the door and window jambs are as much as 1/2" out of plane with respect to the surrounding drywall, which itself is quite wavy. The previous trim was thin and relatively flexible and seemed to twist and conform and spanned the gaps without much difficulty. But I am replacing it with 3/4" and 1" thick flat mdf that has no such flexibility. I tried scraping away the wallpaper edge ridges but decided this route was too messy and too time consuming. So, instead, I have been using a table saw to rip grooves and flats on the backsides of my new casing as necessary to get it to lie flat. This has also been time consuming but the results have been good so I have persisted with it, but now it has been suggested that there is a better method. I was not told what that better method was, though. Is there a better way? What might it be? Thanks!
ngarwood is offline   Reply With Quote
Old 03-18-2015, 08:43 AM   #2
Rewards Points: 1,344
Take you hammer and beat hell out of the raised part, than sweep away the uyack that falls. Same for doors/windows....smack down the wallboard starting hard closest to window edge and then easing as you reach towards the edge of the molding. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
gdc (03-18-2015)
Old 03-18-2015, 08:48 AM   #3
Rewards Points: 144
That's the down and dirty method but will work.If I was going that way I would score the wall with a utility knife first to make sure it does not break where you would not want it to.
mako1 is offline   Reply With Quote
Old 03-19-2015, 12:10 AM   #4
This seems like it should work. I will give it a try. Good call on scoring the drywall first.
Old 03-19-2015, 05:30 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
beating the drywall does work however if your dealing with plaster dont even consider it as you`ll have a lot a ton of patching to do afterwords
ploughing out the back wors well,, also ive pre assembled casing first then nailed it to the gym .. a little more time consuming but it keeps the miters tight
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
BigJim (03-20-2015)
Old 03-20-2015, 07:56 AM   #6
Scoring the drywall and then hammering it down seemed, at first, to be an effective solution. That is, until one of my hammer blows landed on a visible part of the drywall and suddenly went from being an efficient little marvel to a major pain in the butt as I had to stop to patch a hole in the drywall. Maybe I just have poor aim :-\
So contouring the backside of the molding once again seems like the best way to go. But why is it that none of the instructions online for installing molding cover this? Surely I'm not the only one whose house has wonky walls.
Old 03-20-2015, 08:08 AM   #7
Man of many hats
wrangler's Avatar
Rewards Points: 354
Can you not just score the drywall and peel it off?
Man of many hats
wrangler is offline   Reply With Quote
Old 03-20-2015, 08:59 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,476
The reason is, your wall paper was installed wrong, it should never have been turned up on the edges, the hanger took the easy way out and made it harder on you.
I am with woodworkingbykirk, if that is plaster instead of sheet rock, you best not be beating on it with a hammer, you can mess up way more than you want to fix. Most sheet rock isn't real wavy, as you described, but plaster usually is or can be.
Using a hammer is the way I also use to take care of imperfections like that. Scoring the sheet rock at least 1/4 - 3/8 inch behind where the trim will cover is a good idea and can save some extra work sometimes.
If you wish, you can use a wide taping knife (putty knife) and hammer to remove the excess stuff also.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Should I paint my original trim white? somecallmemike Interior Decorating 23 05-11-2012 11:22 AM
Best way to do trim? ligyron Carpentry 4 02-17-2012 09:23 PM
First timer on Trim, need some tips. laflsyl10 Carpentry 10 01-26-2012 01:24 PM
Hardi Board Trim installation tips?? JulesB Building & Construction 8 03-24-2011 08:05 PM
1000sq ft of teak, do i remove base trim, saw door casing ?? PendletonCowboy Flooring 4 10-20-2009 04:04 AM
